Liked 115 Times in 35 Posts
Does anyone make a stock replacement shelf flat top 283 piston larger than .060 over? This would be for a restoration project and the block is at .060 now. Early 721 nova block.
Liked 334 Times in 181 Posts
at one time Federal Mogul made them--- not sure if they are still available--FED 387
Liked 46 Times in 20 Posts
Check with Egge Machine. They even have 4in 283 pistons for a old school 301.
Liked 30 Times in 17 Posts
Jim,
Looks like Silvolite has them in .080, part number 1412. Hope this helps,
Bill Koustenis |
Thanks for the info.
Liked 354 Times in 120 Posts
That block will go to 4 in without any problems, save the hassle with getting the big overbore stuff. Put a 327 SJ crank and stock 4 in bore piston and have fun. Most of 721 blocks were good pieces and were built to go to the 327 in the 65 cars. Tom
Tom Meyer 5240 SS Stock ??? |
Tom, that is what I intended to do with this block. I am selling this block and the guy who needs it for his 64 nova is afraid it will run hot at 4.00. I told him that it has been done before but it scares him. Oh well go figure.
BTW I also have a 3862194 block from a 67 nova, are these as thick as the 721 blocks? Never had it sonic tested. |
#8 | |
James Schaechter 3163 STK |
Is it worth the cost or necessary to put 4 bolt caps or fill the 721 block for a race car motor? This block I have was from a old modified motor. 3.935x3.00 292 cubes. Not filled and stock caps.
I guess it depends upon the power and rpm. We put studs on ours, but kept the two bolt caps. Never had issues and went 8000 plus in our stocker.
