Old 02-03-2015, 05:49 PM   #11
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: What would it take?
Cooter,
Smart move to stay in J & I with a 350 / 268 combo ... Yes, G & H are very Fast classes, which means more bucks !!! Cooter, have you had the car out testing yet ??? Good Luck , see you @ VMP in March .....( CCRA )
Dave Ribeiro 1033 STK
Old 02-03-2015, 07:41 PM   #12
HR9121
HR9121's Avatar
Default Re: What would it take?
Dave, I actually was able to make Darlington race at the end of last year and CCRA race at Dinwiddie, and Steven Rowe drove it at Reynolds lodrs race last year. Got some good data to go off and it's promising but needs a little work. I was looking forward to the division 2 races until I saw the schedule, it's likely that I only go to Dinwiddie and Rockingham for the start of the season.
James Williamson
W200 J/SA. SS/JA
Old 02-04-2015, 10:28 AM   #13
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
Originally Posted by Gary Parker View Post
It's more than just horsepower. Without the right headers, converter, ignition, and carb. Also the car has to leave the starting line hard. Two cars with the same horsepower, will run different times. It's the whole combo and how good one is at making it run. But like has been said on here, bring your wallet.
x2 Gary !
mat H/SA is offline   Reply With Quote
Old 03-15-2015, 02:45 PM   #14
Mag00
Originally Posted by NHRA 303 View Post
This is one of my favorite web sites. Ive killed hours playing on it. Everything is pretty much spot on. Except the ".Compute ideal MPH and times at 60', 330', 660' and 1000'. They wont match your cars times for some reason. But they are proportionally correct.
The "ET - MPH - HP Calculators" in the first column. And the 'Gears - Tire - RPM Calculators' at the top of the second column are my favorites.
Hope this helps.
Steve-o-
http://www.wallaceracing.com/Calculators.htm
keep in mind that most of the online calcs use factors for a standard geared vehicle.
case in point : check the MPH vs ET on a typical street combo , say for instance 13..XX ET at 105 MPH.. now look at the ET vs MPH in a science car.. very similar MPh but a way lower ET.perhaps a .6 0r .7 lower ET.
To best work the numbers within a small window, just pick up a 10 buck calc that does CUBE root..
Now try the mph X 426.. now take the result and multiply it times itself two times i.e. 426x 125mph = 532 ..so .532x.532x.532= car weight as raced, say 3310 pounds...= 499.78 HP,. so plug that number(500HP) in the Wallace ... . all still following? that is common hot rod math.. now the calcs are set up with a factor for ET of around 5.8 ( usually 5.825) but a well setup drag car is closer to a 5.6 factor...So what you see are numbers maybe like an ET of 10.9X at about 124 mph... so instead of using 5.8ish use 5.6 like: 3310/ 500 = 6.62 Lbs /HP..now find the cube root.. 6.62 cubed = 1.877670269 x a factor of 5.825= 10.93 ET so try a factor of 5.6 for a well scienced car and you get 10.51. That should be about the ideal ET. case in point a previous record GSA car ran 125 at 10.58 .. pretty close for a 9.99 (plus tax where applicable) calc.. So you can back track and if you know the MPH and weight you can see who is making HP, got car hooking and who is full of./..A 3500 pound Nova that the owner says makes 600 hp and runs 118 mph is NOT making 600 hp.. closer to 450.. Yeah, you can run a 11.40 @ 125.. or a 10.50 .. MPH takes HP.. ET takes a complete package... Hope that helps and I was not too obtuse..
Mag00 is offline   Reply With Quote
Old 03-16-2015, 11:35 AM   #15
HR9121
HR9121's Avatar
Are you friends with Beard or Piatek lol, they always blow my mind too!
James Williamson
W200 J/SA. SS/JA
Old 03-16-2015, 01:10 PM   #16
James Perrone
Liked 1,840 Times in 428 Posts
What would it take to go 1070s in G/SA...?
Can someone please tell me? Not easy to go 10 anything..Yes wallet is required.
Wallet cant work on car .
james perrone 1290 STK
Old 03-16-2015, 01:55 PM   #17
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Solution is easy. Buy Parker's Corvette!
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 03-16-2015, 03:57 PM   #18
Gary Parker
Liked 425 Times in 56 Posts
Roflmao
Gary Parker 1617 STK
Gary Parker is offline   Reply With Quote
