Liked 37 Times in 8 Posts
Looking to buy a truck to tow my 24ft. race car enclosed trailer. Does anyone know how the Dodge Ram 2500 5.7 Hemi's tow? Do they have enough power? If I were to guess, I would say my trailer weighs around 7,000 lbs. with my car in it.
Thanks, Kevin Clark |
Liked 584 Times in 94 Posts
John Dinkle has been using this combo for years, and he has a small slide in Camper on it.
I switched from a 2011 Dodge 1500 Longhorn 5.7 Hemi to a 2014 Dodge Ram 3500 with also the 5.7 Hemi engine. Although I have not towed with the new truck, based on my towing experience with the 1500, I don't see a problem towing 7K lbs.
Liked 3,227 Times in 981 Posts
Decent tow rig, have pulled with the hemi and Cummings, just don't expect to sail up major hills with the hemi. FYI that a decent sized enclosed steel trailer is typically going to weigh close to 5000 pounds...what are you pulling exactly?
Liked 204 Times in 54 Posts
Don't know about the Hemi, but I pulled at 10K trailer with a 2500 two wheel drive, cummins, automatic and 4.10 gears no problem.
Gears and two vs. four wheel drive would make a big difference. |
#6 | |
My Super stock car weighs 3400 lbs. |
#7 | |
So you actually towed with the 1500 5.7? How much would you say you were towing? |
Liked 13 Times in 3 Posts
I tow my Hemi NSS Dodge all over the place with an 05 Durango 5.7 Hemi, and it's great. Although I use an open trailer and the total car and trailer is somewhere around 5500 lbs.
But, it has power to just sail up these mountains in Western Pa., I can top them at 75 mph, easy. It also gets terrific gas mileage with the MDS, over 18mpg pulling the trailer. A friend of mine pulls an NSS 62 Plymouth in an enclosed with a similar setup, and has close to the same results. Can't beat it. |
I had an 03 Ram 2500 Hemi that towed a 26' enclosed trailer with a 3000lb car with no problem. Only thing i didn't like is the transmission hunting gears. Got a Cummins after that would never go back to a gas engine towing again.
Billy Kirpens Jr / Pro ET / Street ET 123J @ Lebanon Valley Dragway Stock/Super Stock 123A |
