Old 02-28-2015, 03:39 PM   #1
Green2x85
Default E shift ?? 200 metric
If you have one with E shift can you run it manually, I had been told you had to run power to the plug on the side of the tranny and was just checking thanks.I took a glide out and put this one in and I do not have an e shift controller
Green2x85 is offline   Reply With Quote
Old 02-28-2015, 05:22 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: E shift ?? 200 metric
didn't know they made 200's in anything but linkage shift (rather than electronic)....
Old 02-28-2015, 06:10 PM   #3
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Who made the valve body?
Old 02-28-2015, 08:44 PM   #4
Liked 1,922 Times in 432 Posts
E-shift is Turbo Action. You can bypass the E-shift function and make it a full manual.
Old 02-28-2015, 09:29 PM   #5
Green2x85
I put 12 volt to the plug on the side and it will do the 2-3 but not 1-2.Checked shifter linkage everything is fine.There is 2 prongs on the side one goes to 1-2 shift the other to 2-3 both have 12 volt.If i take the 12 volt off it will not do 2-3 shift so i no that gear can be bypassed.The bad thing is I dont have much info on the trans so there may be something wrong with it and i am just fighting a losing battle not sure.Thanks for the help!!
Old 02-28-2015, 10:24 PM   #6
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
If you put 12v to both prongs it should work manually. There is a solenoid that controls each shift. It could possibly be a faulty solenoid.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 02-28-2015, 11:22 PM   #7
Bobby Brannon
Liked 104 Times in 35 Posts
You can but you change wires at E-Shift
Bobby Brannon 4705 STK, SS
Bobby Brannon is offline   Reply With Quote
Old 03-01-2015, 01:49 AM   #8
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
Is this an NHRA Stock Eliminator car???????????????/
If it is a Stocker that ran a PowerGlide than I don't think that an E-Shift TH-200 is legal?????
This is what the 2015 NHRA Rules Book states:
"Electronic rpm controls for the electric (internal or external to the
transmission) shifting of automatic transmissions permitted in
computer-controlled vehicles only"
Just my thoughts,
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 03-01-2015, 12:16 PM   #9
rod butcher
Liked 132 Times in 27 Posts
I have seen E-Shifts in a few non computer controlled cars. This might be something for NHRA tech to look for going forward.
rod butcher is offline   Reply With Quote
Old 03-01-2015, 01:38 PM   #10
Rob Petrie E395
Liked 216 Times in 77 Posts
IF you not using the controller box. And you still have to move the shifter to make it shift. Your not really using E-shift are you? The way I read it that's what he is trying to do. Which sounds ok to me but I'll admit I'm still new at this.
