Old 03-03-2015, 03:50 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,388 Times in 504 Posts
Default Are my radials ruined?
Got the new Mickey pro bracket radials and had them mounted to an old set of weld pro stars that had screws in them. Left them to be mounted and balanced and told the guy to ditch the screws. I left them overnight and when he got to them the next day he used the screws. Should I take them out? Leave them in? Swore I read somewhere to never use screws on radials.
'65 Mustang SS/L & L/SA
Old 03-03-2015, 04:24 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Are my radials ruined?
Can't see them being ruined Bobby, but I would pull the screws. I plan on using an old set of Welds myself that had been pinned from the backside...sans the screws.
Rich Taylor
I/SA - 321
Old 03-03-2015, 04:29 PM   #3
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Take them out ...The SW on radials do not absorb like a slick. It puts more strain on the bead and screws. If the screw breaks and tire slips it will tear the cords out on the bead... Glue them instead...
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 03-03-2015, 04:51 PM   #4
Tony Corley
Liked 61 Times in 25 Posts
Should be a non-issue. The very worse that could have happened was if the screws were long enough to go through the bead, and even then it wouldn't be a real issue, you would just seal the holes. As suggested above, glue them, that's all they need.
Tony Corley is offline   Reply With Quote
Old 03-03-2015, 08:09 PM   #5
pmrphil
Liked 397 Times in 153 Posts
I have a customer that's turning the tire on the rim - what do you use for glue?
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 03-04-2015, 02:08 AM   #6
HandOverFist
Ours moved a bit when running 17psi...now we use 20psi and has not moved since. I don't know about any glue myself.
Rich Taylor
I/SA - 321
Old 03-04-2015, 08:29 AM   #7
Tony Corley
Mount the tires on the rim. Before airing them up and setting the bead, wipe the bead and rim with brake cleaner. Brush Permatex High Tack on the bead of the tire and rim. ALLOW IT TO SET UP/TACK BEFORE YOU INFLATE THE TIRE AND SET THE BEAD!! There may be other ways, but I know this has been working well on a stock suspension, twin turbo big block mustang that runs 4.20's with a 275 drag radial, so should work just fine for a stocker.
Old 03-04-2015, 09:21 AM   #8
Liked 10,965 Times in 2,260 Posts
I would remove tire from wheel and remove any raised portion of the wheel where the screws went through. When the tire slips on the wheel it will be smooth and not cut the tire in the bead area. Ask them to use water to install tire on wheel instead of the tire soap.
Old 03-04-2015, 09:33 AM   #9
HR9121
HR9121's Avatar
Bobby I had screwsin my radials on my hot rod car a few years ago, tire was slipping using a trans brake. I ran several sets like that without any issue at all, not saying it might not be a problem but I never had one.
James Williamson
W200 J/SA. SS/JA
Old 03-04-2015, 05:59 PM   #10
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
clean the wheel's and tire's bead with acetone then mount them DRY, no nothing and they won't move! Been running radial slicks for 15 years, 30/10.5 and 32/13.5. sixty footing as quick as 1.17 in the Firebird to the left without issue.
