Old 02-26-2015, 11:22 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default New flexplate time
It's time to replace our flexplate. Are any better than the others in any
way, I.E. initial movement, E.T. or ??. The Canadian Dollar is dropping
like a rock, so it's very important we buy the right part once, rather than
my normal sequence of buying "right-priced", and then finding out there is better stuff and buying a second one!! Thanks in advance for any meaningful input. J.R. (Smallblock Stocker, 200 Metric.)
J.R. Haddad is offline   Reply With Quote
Old 02-27-2015, 12:14 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: New flexplate time
If you are looking for durability , the Meziere billet wheel is as close to indestructable as you can get ....Yes they are expensive but its the only plate I"ve had that lasted the life of the SFI sticker.
They can repoint the teeth when you get it recerted, comes back like new.
If you use a 153 tooth , it weighs in under 6# .
Old 02-27-2015, 12:34 AM   #3
J.R. Haddad
Tom, I just priced that one out after your recommendation, YIKES, it
isn't cheap! I would need to see H.P. or E.T. to make that purchase.
Great recommendation though. Thanks, J.R.
Old 02-27-2015, 01:01 AM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
You can't go wrong with a flexplate from ATI.
Old 02-27-2015, 09:57 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,966 Times in 595 Posts
We have the Pioneer in two cars. Work great and priced good.
Mike Pearson 2485 SS
Old 03-01-2015, 11:36 PM   #6
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Originally Posted by j.r. Haddad View Post
it's time to replace our flexplate. Are any better than the others in any
way, i.e. Initial movement, e.t. Or ??. The canadian dollar is dropping
my normal sequence of buying "right-priced", and then finding out there is better stuff and buying a second one!! Thanks in advance for any meaningful input. J.r. (smallblock stocker, 200 metric.)
Do not buy a Reactor !!
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 03-04-2015, 06:01 PM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
This ^^^
Old 03-04-2015, 07:21 PM   #8
J.R. Haddad
Thanks everyone, I appreciate the responses. J.R.
Old 05-22-2015, 06:46 PM   #9
Straight Shooter
Sorry to drag this back up.
What's wrong with Reactor? I just had a custom one made for my 10,000 rpm setup. Both my engine guy and the transmission guy recommended it. This week end will be out first race on it.
Straight Shooter is offline   Reply With Quote
Old 05-25-2015, 09:05 AM   #10
Shake & Bake
Liked 37 Times in 33 Posts
The Internally Balanced Billet Meziere 168 tooth only weighs 6.3 lbs. I like the "one" piece design.
Like Tom stated: they are pricey, but you get what you pay for.
Shake & Bake is offline   Reply With Quote
