Old 03-14-2015, 11:54 PM   #11
STR001
Default Re: Front end rise
Just an update: I took the front moroso springs out of the car today so that I can cut another coil out to get the ride height correct. I noticed that the lower control arm bushings seems to be binding. These are new polyurethane bushings and seem to be thicker than the stock rubber ones. I cut the bushings down some to give some added clearance. It looks like there is no resistance issues that I can tell. So hopefully this help solve the front end rise issue. Thanks for all the help and suggestions. Jason
STR001 is offline   Reply With Quote
Old 03-15-2015, 12:13 AM   #12
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Yes, I used poly on the Mustang as well Jason and had to do some trimming to free it up.
Rich Taylor
I/SA - 321
Old 03-15-2015, 06:38 AM   #13
Greg Barsamian
Liked 427 Times in 97 Posts
Look at using these:
https://www.motorstate.com/site/cata...=66&loadord=71
Old 03-15-2015, 05:55 PM   #14
Bruce Fulper
Liked 54 Times in 33 Posts
To be polite, guessing is tough and of course a lot of us have no other way to approach fixing a problem. But there's a complete way out. Complete answers to all of your suspension questions can be found in one book. Very easy to understand too. Very easy. You can buy this book on Amazon used approx. $40 usually. Then you'll have everything you'll ever need to know in one book. It's titled "A Chassis Book - DoorSlammers" by Dave Morgan.
Bruce Fulper is offline   Reply With Quote
Old 03-15-2015, 06:56 PM   #15
HandOverFist
Had it before there was even an Amazon...still have to put hands on the car. If a book could easily solve all problems then there would be no need for this forum.
Rich Taylor
I/SA - 321
Old 03-16-2015, 02:20 AM   #16
Bruce Fulper
An exceptionally thoughtless reply. Good for you. Really trumped gathering a complete education right there.
How about this - With the book, you do not need anyone here.
Jesus.....:-/
Old 03-16-2015, 05:02 AM   #17
HandOverFist
Jesus.....:-/
Really??? You could have well just quoted yourself Bruce...and let's leave Jesus out of it.
Exceptionally thoughtless reply? You were being condescending suggesting that a book would "completely" negate any need for inquiry or discussion about a specific problem. Books are wonderful things at times, but they do not always provide the wealth of experience from those that have "been there - done that". It is infuriating at times to ask questions and get responses like "hit the search button" or "buy a book". To paraphrase, I believe my reply is "very easy to understand...very easy". Let's just say your reply was poorly crafted and leave it at that. My apologies to Jason for fouling his thread.
Rich Taylor
I/SA - 321
Last edited by HandOverFist; 03-16-2015 at 07:30 AM. Reason: more thoughts about the subject
Old 03-16-2015, 10:00 AM   #18
Eman
Liked 133 Times in 76 Posts
Not sure what you mean by recoil. My 90/10's do keep the frt. up, if you let the car down on the lift it takes a while for the frt. to settle. Global West makes bushings that won't bind. I don't have a stocker but I had steel bushings made with grease fittings so the arm just drops freely. It took a few in and outs to cut the Moroso springs down enough to get the reaction I wanted. Those springs can get your heart pumping! Morgan's book is good, but it's not an easy read.
Old 03-17-2015, 11:03 AM   #19
STR001
Enman: What I meant by recoil was that on the launch the nose would rise and transfer the weight. Then the nose would come down (recoil) and raise up a second time. Only this time the nose would stay up throughout the entire run. I think I have that issue solved since I have freed up the lower control arm resistance. I did come across some nice heavy duty steel bushings for the lower control arms at www.ubmachine.com They look like good quality stuff. Should have them here in a few weeks. For now I shaved down the polyurathane bushings to free up the lower control arms to see if my theory will work. Plan on testing the car this weekend so i will let you know how it goes. Jason
Old 03-19-2015, 08:39 AM   #20
Eman
I had a similar problem. The car would launch and the frt. would rise then drop and rise again. A video showed tire spin causing the frt. to drop suddenly. Weight transfer and adjustable rear coilover shocks helped mine.
