Old 03-13-2015, 09:36 AM   #1
mishsc
Default Cleaning out the garage. Here's a list of parts for sale.
Th400 transmission. Has been cut for a Ultra-Bell. Set up for a Super Stock car. Reverse pattern. No brake. Fresh with zero runs. $1,350
Quick Fuel Super Stock legal 780 carb. Brand new. Never been on a car. $500
Holley #3310 780 carb built by Quick Fuel. Comes with spacer, return springs and bracket. $175
Ross hc425 BBC pistons w/Childs and Albert steel rods. $275
Manley 221448-16 valve springs. New in the box. Have a full set and half of another set. $550
Also have 29 used with w/16 retainers. $115
Comp Cams 948-16 valve springs. Used w/retainers. $50
Quick Fuel 22-804 jet kit. New in the package. $45
Assorted jets and 2 QF jet cards. $45
Richmond 5.29 Pro gear set. Lightened. Low runs. $150
LSM tools for BBC $475 for all 3 tools (Spring changer,tester and adjusting set)
BBC steel crank. Used. $425
Must pick up in Clarksville IN.
Let me know if you have any questions.
Pictures on request.
Shane
502-727-9909
mishsc is offline   Reply With Quote
Old 03-18-2015, 08:48 AM   #2
Feltham.Justin11
Default Re: Cleaning out the garage. Here's a list of parts for sale
More info on the springs? Size? How much lift they can take?
Feltham.Justin11 is offline   Reply With Quote
Old 03-19-2015, 10:06 PM   #3
mishsc
Brand:Manley
Manufacturer's Part Number:221448-16
Part Type:Valve Springs
Product Line:Manley NexTek Valve Springs
Summit Racing Part Number:MAN-221448-16
Number of Springs Per Valve:Triple
Outside Diameter of Outer Spring (in):1.677 in.
Coil Bind Height (in):1.142 in.
Damper Spring Included:No
Spring Rate (lbs/in):733 lbs./in.
Inside Diameter of Outer Spring (in):1.195 in.
Inside Diameter of Inner Spring (in):0.635 in.
Valve Spring Style:Standard Not sure which set of springs you are asking about. Brand:COMP Cams
Manufacturer's Part Number:948-16
Product Line:COMP Cams Valve Springs
Summit Racing Part Number:CCA-948-16
UPC:036584280385
Outside Diameter of Outer Spring (in):1.645 in.
Coil Bind Height (in):1.130 in.
Spring Rate (lbs/in):686 lbs./in.
Valve Spring Style:Standard Hope this is the info your looking for.
Search this Thread:
Advanced Search
