Old 03-29-2015, 08:14 PM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default Clutch, traction bars, flexplates
For Sale:
-Soft Lok clutch set up for LT-1 that is externally balanced. It has the weight to balance it to the LT-1 specs bolted on, it could probably be used for a neutral balance but balance should be double checked after removing weight. 11" clutch 168 tooth aluminum flywheel, 10" friction unlimited disc 18 spline (.320 current thickness) Last freshen up was done by Advanced, (ballpark 125 runs ago). Have more pics I can text or email $800
-Lakewood 21700 traction bar set up for 82-02 Camaro Firebird. Comes with rear end brackets and lower bars, you will need to weld tabs on your lower control arms. $100
-Reactor flexplate 168 tooth, for 1957-85 SBC internally balanced. Has 4 of the alan bolts that hole the ring gear on broken. $70
-Jegs brand heavy duty 153 tooth flexplate for 1957-85 internally balanced. New in the box $25
All item plus shipping.
call or text (616)437-4958
email brad@zaskowskibuilders.com
Thanks
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 03-29-2015, 08:34 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Clutch, traction bars, flexplates
PM sent
Search this Thread:
Advanced Search
