Old 04-01-2015, 08:02 PM   #11
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Q-jet Fuel Pouring out
I was hoping JP Schuster had some words of wisdom, about his Q-Jet problem.
Old 04-02-2015, 01:44 PM   #12
JP Schuster
Nothing yet, guys. I apologize. I slapped my spare carb on for now and it was fine. I do appreciate The help with fuel pressure. I think that could've been one of my problems. The carb was completely fresh but sat without fuel in it for about a year, so I think i will take it apart and see if anything is stuck. Sorry to keep you guys waiting! I will respond as soon as I get some time to take it apart.
Thanks for all your help!
JP
JP Schuster is offline   Reply With Quote
Old 04-15-2015, 02:06 PM   #13
JP Schuster
Hey guys, just another update:
Being the rookie that I am with these carbs, I looked right past the fact that the needle and seat could be stuck... It was a fresh Q-jet, however it sat for a number of months before actually getting to put it on.
Nonetheless, I was told to tap the front of the carb, pulse the fuel pump for the initial filling of the bowl, then let it rip.
Sure enough, no leaks.
Thanks everyone for their help and technical expertise! It was just a simple fix (or procedure) that got me back on the right track.
Thanks,
JP
Old 04-15-2015, 02:57 PM   #14
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Yep, knocked on quiet a few Q-jets over the years. If you take your stored carbs and run a little atf thru the needle/seat and accell pump after draining everything goes much smoother the next use.
Rich Taylor
I/SA - 321
Old 04-15-2015, 05:09 PM   #15
Run to Rund
Liked 54 Times in 27 Posts
If the Viton tip of the needle valve is dried out from age, etc. you will get it to work for a while, then it will leak again. I had this happen with Rochester 2-jets and new needles and seats fixed it.
