Old 04-02-2015, 01:44 PM   #1
hardtimes
Default ladder bars
I have heard different things, but how should a ladder bar car be set up as far as the angle of the bars. I have heard level, down, and a few say up. what is right.
This is a 3000lb car w driver that has ladder bars/coil overs with Qa1 single adjustable shocks on the rear a 29x10.5 slick and runs 6.60's in the 1/8th mile NO trans-brake
What spring should it have I have heard 110 and 130. where should the shocks be adjusted to start with.
hardtimes is offline   Reply With Quote
Old 04-02-2015, 02:33 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
Default Re: ladder bars
set your ladder bars up with 2 degree down angle with respect to the bottom of the rocker panel on the car. put a protractor or smart level on the rocker panel see what degree that is and make the bottom bar on the ladder bar 2 degrees more down angle. put 2 degrees down angle on the pinion. My car weighs 3165 and I have the same type shocks as you. I run 110 lb springs. I run my shocks 2 clicks from loose
Mike Pearson 2485 SS
Old 04-03-2015, 10:33 AM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
I think that any racer who wants to work on their suspension owes it to themselves to buy Door Slammers: The Chassis Book by Dave Morgan...
A very good read with a ton of info.....
I bought mine over 20 years ago.....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 04-03-2015, 12:03 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Originally Posted by Bob Mulry View Post
Hi,
A very good rear with a ton of info.....
Bob
Same here...it helped a ton working with my first 4-link and all the info is still relevant.
Rich Taylor
I/SA - 321
Old 04-03-2015, 12:22 PM   #5
jmcarter
jmcarter's Avatar
Liked 3,226 Times in 981 Posts
The book is only $43 on Amazon, hard to beat.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-03-2015, 04:43 PM   #6
Dragsinger
Liked 99 Times in 60 Posts
Hard,
The setup Mike presented has worked well for me with three different cars. [the slightly down position]
I "think" with the average, slightly front heavy door car, that is a good setup.
In addition, a rear anti-roll bar will change a very good working car to an excellent package.
With three different situations, I have personally experience cars that were very consistent become copy machines with the addition of a rear anti-roll bar. [all three ladder bar setups]
A 1990 Firebird that I campaigned for several seasons with the above setup could and did win without changing the dial in over a race of 7 - 8 rounds. It ran an average ET 6.15 in the 1/8th.
Larry Woodfin 471W
Old 04-03-2015, 08:13 PM   #7
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
What if the car likes a little pre-load on the right bar? Is that the 2* down bar?
Ron Gusack is offline   Reply With Quote
Old 04-03-2015, 08:19 PM   #8
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
No. The preload pulls the front of the ladder bar up.
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 04-05-2015, 12:33 PM   #9
Johnny Rod
No pre load!!! Because for every action there's a reaction.
Johnny Rod is offline   Reply With Quote
Old 04-14-2015, 12:56 PM   #10
hardtimes
I have qa1 single adjustable shock on the rear. my question is every time I tighten the shocks up the car works better. they have 12 adjustments I am at 7 from soft. car works better every time I tighten them, but it rides like a old haywagon. would like to get the car just a bit better should I tighten them even more or should I move the bars down one hole and loosen the shocks up some at this point.
