Old 04-21-2015, 07:39 PM   #31
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Default Re: Apparently Div7 has more than 1 rule book !!!
It is a simple thumbs up if you improved and thumbs down if you didn't. Usually right before scales or fuel check....whichever comes first....why waste everyones time to fuel check or weigh if the run does not count????? Btw I have no complaints with
Mike Rice..
Old 04-21-2015, 09:34 PM   #32
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Here is the deal with the said racer we watched do this. At Vegas when the line is long enough its behind the slip booth scales and fuel check . Every racer should know you do not just assume you're not going to get weighed or fuel check regardless if you improved , that is at the discretion of the tech official . But to blatantly drive past all looks pretty suspicious and per the rules its grounds for DQ . My point was to bring into light the lax of rules that were being implied through this whole event including what happened to Mikey... like someone posted we pay to have a level playing field regardless of the rules and it should be brought to the attention of the officials but when the officials don't care who does ??
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 04-22-2015, 11:15 AM   #33
Bryan Worner
Liked 535 Times in 86 Posts
We went from ice falling off a car going down the track, to not crossing the scales!
Back to the original point. First, if I was the guy with the faster car that "couldn't" lose, I would not be putting ice on my intake! Second, the rule is very clear. It must be off the car prior to leaving the staging lanes. So the winning racer here deserves to be DQ'd!
Bryan Worner is offline   Reply With Quote
Old 04-22-2015, 11:18 AM   #34
KThomas
Liked 6 Times in 4 Posts
Ditto --
KThomas is offline   Reply With Quote
Old 04-23-2015, 11:47 AM   #35
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I agree... and what about the Championship Points..............
Patric Fox is offline   Reply With Quote
