Old 05-13-2015, 10:45 AM   #1
Michael Iacono
Liked 6 Times in 6 Posts
Default Can Stockers use the small Braille battery?
Jegs has the 12v 6.9lb Braille battery for $150 and I was wondering if its legal to have in the battery tray in the engine compartment in Stock. Does it have to start the car? What if I have a 16v battery in the trunk that starts the car? Is the small size an issue?
thank you
Michael Iacono is offline   Reply With Quote
Old 05-13-2015, 10:58 AM   #2
bdixon
Liked 15 Times in 7 Posts
Default Re: Can Stockers use the small Braille battery?
Michael I have used the 17 pound braille for the last 2 years in the front location, but i only have one battery and has worked great,buttt,,,,in the rule book it says two batterys if used must be same size and weight ...Just depends on what your nhra official says....Bryan D stk511
bdixon is offline   Reply With Quote
Old 05-13-2015, 11:01 AM   #3
Jim Kaekel
Liked 536 Times in 110 Posts
I know if a second battery is used (in the trunk), it must be the same type and group.
Jim Kaekel 3836 STK
Old 05-13-2015, 01:37 PM   #4
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Yes sir we have been successfully using and selling them for over 5 years best batteries we've had since my old Motorcraft group 31s 1000 CCA 70lb bricks
2 in my 65 Mustang SS car 1 in each of our EFI stockers which both have power windows and locks too
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 05-13-2015, 06:48 PM   #5
Matt Welker
Liked 77 Times in 15 Posts
Michael,
You can't go wrong with a Braille battery (unless it isn't correct for the application), and they support not only drag racing in general, they specifically support S/SS racing. All three of our cars will be running Braille Batteries. You'll see the signage and product on our cars and commercial transporter next week at Maple Grove.
Great company and people. Stop by and check out the battery we are running in our stocker, lightweight and no need for two.
-Matt
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
Old 05-13-2015, 07:12 PM   #6
jim morgan
Liked 52 Times in 9 Posts
thank you
Michael, size is always an issue
Jim Morgan 1916 , 9916 STK
jim morgan is offline   Reply With Quote
Old 05-14-2015, 02:40 AM   #7
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Using the B3121 in the Camaro and the B2317 in the Mustang. Great batteries, but I can not recommend their charger (12310) . https://www.braillebattery.com/index...argers/b123101
The charger is great for home/shop use with standard 120v service, but it will not excite/operate on any generator I have tried at the track.
Rich Taylor
I/SA - 321
Old 05-14-2015, 12:59 PM   #8
John Bender
Liked 61 Times in 12 Posts
Michael, I have the 21 lb Braille battery in my car this year and have had no problems with it. The rule book does say if you are running two batteries, they must both be the same size and the front battery must start the car. I just have the one in front.
John Bender E/SA 1967 GTXw
John Bender 1969 STK
John Bender is offline   Reply With Quote
Old 05-17-2015, 06:26 PM   #9
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,388 Times in 504 Posts
Alex what Braille battery would you recommend for the EFI stocker? Is 475 cranking amp enough? I'm using a 6 year old optima red top that weighs about 35 lbs and would like to take some weight off that front end.
'65 Mustang SS/L & L/SA
Old 05-20-2015, 11:34 AM   #10
Tom Joseph
If you run two batteries and wire them in series they have to be the same to work and live. Glad I found this thread as I was booted at Atlanta and had no clue the fake front battery was wrong. The rule is "The battery that has to be in the stock location must be able to start the car" as far as size goes I'm having trouble getting an answer.
Tom Joseph is offline   Reply With Quote
