Old 05-30-2015, 12:00 AM   #11
Don Anderson
Liked 25 Times in 9 Posts
Talking Re: 302 Ford oil pan
Originally Posted by capri View Post
canton seems to do the best job for everything we have seen. We switched to their stuff years ago. No problems even after yanking the pan at the track.
x2
Don Anderson is offline   Reply With Quote
Old 05-30-2015, 02:52 AM   #12
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: 302 Ford oil pan
Originally Posted by Rich67stang View Post
That is the one. check the DIV1 photos from Reading, will show how it sits under car
The Summit link says it won't fit 4 bolt front and rear mains. I have the M6090 BOSS302 block - 4 bolt mains with two bolt front and rear. Will this fit mine? It's in a 68 Coupe.
Dale
Dale Shearon
68 Mustang 6394
Old 05-30-2015, 06:47 AM   #13
1965
Originally Posted by Capri View Post
Canton seems to do the best job for everything we have seen. We switched to their stuff years ago. No problems even after yanking the pan at the track.
I agree. Used canton pan for years and no problem on my Windsor motor. Mine has the kick outs and baffles in it.
1965 is offline   Reply With Quote
Old 05-30-2015, 08:05 AM   #14
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
One thing I noticed on these pans is the rear drain bolt. I have a after market rack n pinion steering in the car that is very tight to the pan in the rear. I wonder if it will clear.
http://www.speedwaymotors.com/Uniste...Kit,38468.html
Old 05-30-2015, 08:58 AM   #15
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
Dale
The Ford Racing BOSS block was designed to use a stock pan. That's why the front and rear main caps are 2-bolt vs. 4-bolt.
Old 05-30-2015, 10:57 AM   #16
FireSale
FireSale's Avatar
And that's why my stock pan fits... [Bangs head on table]...
Thanks. I need to get rid of that thing and the one in the link is priced good compared to the one from Ford Racing.
Dale
Dale Shearon
68 Mustang 6394
Old 05-30-2015, 01:27 PM   #17
rawhide
Liked 7 Times in 5 Posts
Dale
Ford Racing used to use and sell Canton pans but for some reason now has Watson Engineering making them. The Watson pans are more engineered but you do have to pay the price for that. I have seen several different brands of pans on their oval track crate engines.
Roland
rawhide is offline   Reply With Quote
