Old 06-12-2015, 02:20 PM   #1
1969chevss
Default small bore sbc head gaskets
i am searching for a small bore steel shim head gasket for my 307. all i can find is a 4.100 bore. i heard SCE gaskets is making these. Has anyone ordered from there or know if they are making these.
1969chevss is offline   Reply With Quote
Old 06-12-2015, 03:26 PM   #2
Liked 5,118 Times in 1,950 Posts
Default Re: small bore sbc head gaskets
What are you trying to build here?
Old 06-12-2015, 03:38 PM   #3
1969chevss
working on a 69 chevelle 300 deluxe factory 307 powerglide would like to keep my compression ratio up there that's why im looking for the smaller bore .015 steel shim. keeping my options open at this point
Old 06-12-2015, 03:53 PM   #4
Robert Simpson
Liked 20 Times in 12 Posts
I used the .015 Fel Pro gasket on my 307. It was a 4.060 bore gasket I think? Unless you can find some old 283 steel shim gaskets I don't believe you will have a big selection.
Robert
Robert Simpson is offline   Reply With Quote
Old 06-12-2015, 04:01 PM   #5
1969chevss
i was looking at the fel pro 1094 they are advertised as .015 steel shim 4.100 bore. Little big. I guess i can use as last resort
Old 06-12-2015, 04:12 PM   #6
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
I have some 283 shim gaskets at dads shop. Will be glad to inventory gaskets over weekend. I know there at least 2-sets...maybe more.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 06-12-2015, 04:17 PM   #7
You realize you are talking about 3 hundredths of a compression point, of course...
Old 06-12-2015, 06:35 PM   #8
Allen Sherman
Banned
Liked 5 Times in 3 Posts
Your best bet is Cometic, they aren't gonna be cheap, probably 80-90 bucks per gasket but they make a small bore gasket and they also make .018" thick gaskets...they will basically make whatever you want...t
Allen Sherman is offline   Reply With Quote
Old 06-12-2015, 06:57 PM   #9
Great product but I don't believe I'd use them on a restoration project.
Too easy to spot, along the lower edge.
Old 06-12-2015, 07:31 PM   #10
MR DERBY CITY
Liked 7,928 Times in 1,517 Posts
I believe you would be happy with some ole 633 GM gaskets, they are still out there ...you just need to do some searching. M.J.
