Old 06-14-2015, 01:30 PM   #1
ghost
Liked 16 Times in 11 Posts
Default Clearance piston to valve
Hi
I need information. On my B/SA 1995 Camaro with LT1. At 101.5 timing, the valve clearance to piston is .018 int and .053 on exh. It is too tight or is normal. If i back the cam at 106, i have 32 int and 36 exh. All with .039 head gasket. what you do with this?
Thank for your help
ghost is offline   Reply With Quote
Old 06-14-2015, 02:20 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Clearance piston to valve
How are you measuring that ? Light checking spring, or clay, do you have a welded lifter ?
Old 06-14-2015, 03:10 PM   #3
ghost
This is Roller Hydro. but I checked the lash with light spring and solid roller lifter. but i have same result with light spring and roller hydro.
Old 06-14-2015, 03:35 PM   #4
Mark Lewis
Liked 207 Times in 44 Posts
what is the total deck, head gasket and piston depth?
Also what is cam ground on?
Mark Lewis is offline   Reply With Quote
Old 06-14-2015, 04:13 PM   #5
Joe DeMarzo
Liked 120 Times in 11 Posts
Mark you have a pm.
Joe DeMarzo 1317 STK
Old 06-14-2015, 04:45 PM   #6
ghost
deck is .015 gasket .039 total .054.
but i want know?
Have you ever seen this in stock eliminator for a hydraulic roller cam?
Old 06-14-2015, 06:36 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Late model LT-1 minimum total deck with gasket is.062" IIRC. Your short .008" and would fail a tear down. I had one and built my own engine and had plenty of clearance with CP pistons and a Bullet cam. That cam was pretty aggressive so it seems odd to me you would have so little clearance.
Rich Biebel
S/C 1479
Stock 147R
Old 06-14-2015, 07:21 PM   #8
Lee Valentine
Liked 319 Times in 68 Posts
Same thing I was thinking Rich.
Lee Valentine 1661 STK
Old 06-14-2015, 07:52 PM   #9
ghost
I run with with Fel-Pro 9966 pt the thickness is .049 not .039 (it is my mistake) But it changes nothing to my question.
Rich ... you don't need to swear at me
Old 06-14-2015, 07:52 PM   #10
Rich Biebel
It's been quite a while since I had that LT-1 Stocker Lee but I do recall doing that engine and being real happy I did not have to worry about a tight P-V issue. Still wish I had one as they are great fun to drive. Not fun to work on! Swear at you ? I don't have a clue as to what that statement means.
Rich Biebel
S/C 1479
Stock 147R
