Old 06-14-2015, 08:51 PM   #11
Ed Wright
Ed Wright's Avatar
Default Re: Clearance piston to valve
To answer your original question: I would not try to run it that close. Closest I have ever run my SS LT1 is .036" intake (I prefer .040") and .065" ex, measured with checking springs, using a dial indicator, not clay.
Ed Wright 4156 SS/JA
Old 06-14-2015, 09:08 PM   #12
Tom Moock
Liked 10 Times in 6 Posts
ghost, Did you check valve clearance with valve springs that you are going race with? you need a solid roller lifter the same height as your hydraulic roller to check cam lift & valve clearance, you will have more valve clearance with heavy springs. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 06-14-2015, 09:35 PM   #13
ghost
Liked 16 Times in 11 Posts
Thanks for your help
tomorow, i check again with my race springs and solid lifters with same height
ghost is offline   Reply With Quote
Old 06-15-2015, 08:40 AM   #14
Ed Wright
Ed Wright's Avatar
Doubt race springs will get him enough clearance.
Old 06-15-2015, 06:04 PM   #15
ghost
after checking carefully with RACE spring . i have .038int and .065exh at 101.5 timing. Is tight but O.K. for my application
Thank's again
Old 06-15-2015, 07:00 PM   #16
Ed Wright
Ed Wright's Avatar
That is close with race springs. Hope it goes well for you.
