Liked 115 Times in 35 Posts
The ladder bars on my SS/I 67 camaro are 30" long from housing center to front bolt center. Without measuring bars on other cars these seem short. I have them set in the bottom front bolt hole which is approx. 4 degrees down compared to level surface. This along with a stiff rear shock setting has worked best so far with this the stick shift.
Would a longer ladder bar say 33" help? I just can't bring myself to cutting the entire back half out of this car to install a 4 link. |
Liked 285 Times in 87 Posts
Jim…I'm curious as to what your weight bias is? What problems are you experiencing? MB.
Liked 1,944 Times in 585 Posts
The ladder bars on my car are 36 long. My car has always worked well. Check the angle of the bars in relation to the rocker panel. Should be 2 degrees down in comparison to the rocker panel. 2 degrees of pinion angle also
Mike Pearson 2485 SS |
#4 | |
Banned
Liked 179 Times in 89 Posts
This is the book to read. http://www.swracecars.com/store/-Doo...5=95-1000.aspx |
Liked 3 Times in 1 Post
Darin Morgans Doorslammers The Chassis Book also has some good information on ladder bars. I have not looked in awhile but I think Amazon still has it?
Liked 99 Times in 60 Posts
Jim, what is the car doing that you do not want it to do?
Larry Woodfin 471W |
My car worked ok at best with a auto. if I chipped it low enough. Otherwise it would spin on the hit. Now with the stick it has a hard time keeping the tire planted after the initial turn or two of the tire.
The reason for my question was just curious if my bars are shorter than most out there, and if set low enough if it really matters. It would take alot to put longer bars under there and also might hit the floor. |
Banned
There's a lot of possibilities here Jim.
Not enough air in the tires will cause the tires to collapse and break traction with a hard hit. I assume you're running a spring slider. Shock settings are important. A close video of the tires at launch will help analyze the problem. I don't think it's good idea to change the ladder bars without knowing the exact cause of the problem. |
Liked 32 Times in 19 Posts
Dave Morgans book about traction bars will help but if you find it by using the "wives tales" regarding angle of this or that it is a Lucky guess. Need to weigh chassis, front and rear, and use an organized approach to setting up related to instant centers of bars and chassis.. Rocker panel not the same on all chassis etc etc....
Liked 320 Times in 102 Posts
Just a heads up..............
All things equal.......... The higher the front pivot the more HIT (more body separation & more wheel stand) and less forward motion..... The lower the front pivot less HIT (less body separation & less wheel stand) and more forward motion..... A car will always ET better with a lower pivot (instant center) location if you can hook it...... Just some really general rules to look at.... Get the Door Slammers Book by Morgan and you don't have to be a rocket surgeon to make it work..... Bob
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 06-18-2015 at 07:52 PM. Reason: Trying to have stement make sense |
