Old 06-20-2015, 01:16 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Pro Gears
A few months ago I needed a new set of gears for the SS car. Have always had good luck with Richmond, but was concerned that mfg was now offshore, After research I decided to stay with Richmond, Had them professionally set up. Watched the setup. checked the pattern myself,used good gear oil. After about 35 passes they are junk.
They are completely worn out. These gears are junk. I guess I will try US gear next
Mike Graham is offline   Reply With Quote
Old 06-20-2015, 04:15 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: Pro Gears
I never had any luck with synthetic gear oil. It would just grind the pinion down to nothing.
GL-5, 80/140 conventional gear oil gave me the best results.
Chevy55 is offline   Reply With Quote
Old 06-20-2015, 05:35 PM   #3
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Smile Re: Pro Gears
Well Mike you know you are pushing that big torque monster ford,may be hard to keep anything from breaking in it.You might need a Big Rig gear in it.Lol
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
