Old 07-01-2015, 11:18 AM   #1
Mike Crutchfield
Liked 4 Times in 2 Posts
Default Engine and parts
Race engine and parts
________________________________________
SBC-321ci complete engine fresh off the dyno 12degree Slawco,Bow-tie block-All Jesel front distributor, jesel belt, jesel rockers, jesel lifters, ATI balancer, CSR water pump, Moroso Pan, Hogan manifold with 2x4 and 1x4 tops, MSD crank trigger, King light weight crank and much more. Ran 8.80 in SS/BS trim Priced TO SELL- $9000
1-Moroso aluminum SBC oil pan for external oil pump, driver side starter $350
1-Crank Trigger wheel bracket and NEW Moroso pick-up $125
Mallory Hyfire Pro ignition box- $150
221147 and 22148 Manley polished triple valve springs with titanium retainers -$200 per set
Jesel keyed lifter 8 offset 8- centered- $500
Comp cam NEW roller lifters 8-offset 8-centered- $250 per set
Moroso chrome valve covers $40
TCI- 7inch converter 13-30 .050tc- $400
2-123 tooth Chevy Aluminum Reactor flywheels 1-new $100 1-used $75 and starter noise for flywheel
Powerglide less planetary and front clutch drum and input shaft - Basically a Case with steel pan, pump, pro-brake and solenoid $350
NEW in the box- Power Glide Aluminum pan $50
4- Powerglide trans-brake solenoids $35 each
Very rare Jeep 904 transmission core with Chev bell housing bolt pattern $300
Motivated seller -Send offers or questions to
mikec2610@bellsouth.net
Mike Crutchfield is offline   Reply With Quote
Old 07-01-2015, 07:12 PM   #2
jmlynch
Default Re: Engine and parts
I am interested in the powerglide and trans pan give me a call at 615 7929113 thanks sorry don't know to e mail this is good number to call between 830 and 7 oclock thanks MIKE
jmlynch is offline   Reply With Quote
Search this Thread:
Advanced Search
