Old 06-30-2015, 10:29 PM   #31
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: Pro Mod or Pro Stock?
Originally Posted by FS Fan View Post
Between the two I prefer Pro Mod for the following reasons
Unique power trains. NHRA has done a really good job balancing out different combos. Pro Stock has become cookie cutter powerplants that don't resemble anything ever built but any of the factories.
Big fields - you actually have to qualify BUT the competition is close enough that you can not qualify and then win the next like Bill Glidden did this year.
Also the limited schedule and costs associated with the cars help get more Pro Mod participation. The fact that other sanctioning bodies have similar classes helps also. If you don't think Pro Stock has too many races last year Enders took a couple off and still won the championship. Also there are a handful of races that don't get all 16. Pro Mod's schedule looks better to me. And I have heard pro Stock teams are spending upwards of $200k annually in valve springs, $8k for a set of carbs, etc. Hard to bring new people in if that's the cost of being in the running.
Fans - I think Pro Mod draws a younger fanbase. I don't think most kids that are getting into cars are looking at building big block carburated cars and marveling at how they work. EFI, Turbos, nitrous, etc. are relevent to street performance. Search Camaro Supercharger kit and half a dozen pop up in the ads.
Explosiveness. Pro mod has a little bit of that unpredictabilty to it.
This is not to say that I don't respect Pro Stock but if I could only watch one, it would be Pro Mod.
Pro Mod cars are fun, but like the nitro, and alcohol cars,other than the top 6-8 cars, they are NO different than Pro Stock. At Indy, and St Louis 2014 they did not have large crowds watching, and @ St Louis, about half made it down the track, on the last qualifying run, and in round 1,also
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 07-01-2015, 01:32 AM   #32
Liked 1,892 Times in 423 Posts
"Pro Mod" is pretty much the old style more open rules of TA/FC or TA/D from the old days of Pro Comp, stuffed into a stretched wheelbase Pro Stock style chassis. Nitrous on this one, blower on that one, turbo on the other one.
Yes, they can be fast. They also crash on a regular basis, and it is not at all uncommon to see entire sessions where not a single one of them makes a full clean pass. Yes, I understand why that is the case. That does not change the fact that, after the new wears off of it, the fans will look elsewhere.
Old 07-01-2015, 07:26 AM   #33
joespanova
Liked 13 Times in 11 Posts
Don't hold your breath on that one. You have a passion for Pro Stock and if surveyed ( PS to PM ) you'd be in the minority.
Like I said before...........the PS class has become a bore , all Camaros and not very exciting to watch. You can be sure of this................if they don't rethink the concept of the class , it will die off within the next 10 years. Pro Mod will continue to increase in popularity and PS's will diminish.
Pro Stock? Give me a break...........500 inches and carbs? How much more detatched from the production platform can you get?
Small blocks and fuel injection / turbos are waaay more appropriate to suggest anything even "remotely" indicative of Pro "stock".
At a minimum get rid of the 500 inch combos..........
Old 07-01-2015, 09:12 AM   #34
Ed Wright
Ed Wright's Avatar
If you build, or know anything about, building engines, it is hard to not be impressed and fascinated with the power levels, and the technology. Plus close races, and pretty much everybody making decent passes every time.
If your more impressed with noise, explosions, out of shape cars, and track oil downs, fuel cars & pro mods are for you. The vast majority of the people in the stands fall into the latter group.
At national events, the stands still pretty much empty after the fuel cars run. I go up to watch Pro Stock, not all that many stay to watch the pro mod cars. They draw well at small tracks, where everything else is bracket cars. People mostly don't watch the alky cars either. You can pretty much pick your seat.
Ed Wright 4156 SS/JA
Old 07-01-2015, 10:35 AM   #35
Nathan Stinson
Nathan Stinson's Avatar
Liked 4 Times in 1 Post
Originally Posted by Dick Butler View Post
Pro mod is just another noisy bracket car which run fast to draw unknowing spectators.Top Sportsman, Top Dragster are all in the same plan. Allow people to race a fast car without competing to build the most HP from the same motors..or parts. Removes one part of racing but allows racers to run fast and feel they are getting off cheaper.... Less thrashing dyno time etc.
This hands down is one of the craziest, most un-informed post I have ever read on this board! Yes Pro Stock and Pro Mod are different animals and each has there own fan base but to say that Pro Mods are just noisy bracket cars and there is no competition to see who can be the best with a given set of rules in the class is crazy! Tell that to Reher Morrison, Buck, Sonny, or Pro Line. I promise those guys beat up the dynos to make those motors better every day. Tell guys like Bill Glidden, Rickie Smith, Steve Petty etc that they are just running a loud bracket car, and due to the fact it has a power adder on it, requires no technical skill or no changing of parts or set up to go as fast as possible under a given set of rules.
If building and competitively racing a "power adder" car is as easy as some of you think, you should get one and try it some time. You might walk away with a different opinion.
Nathan Stinson is offline   Reply With Quote
Old 07-01-2015, 12:21 PM   #36
Exactly what fuel injected small block Pro Mod car are you talking about? And for that matter, how many supercharged 500 inch cars are they making these days? Especially running on a 14-71 blower and a buzzard catcher, or a 120MM turbo charger, or maybe 2-3 stage of nitrous? Sorry, not buying the idea that a stretched wheelbase Pro Stock chassis and body that looks like a funny car with a 500 cubic inch supercharged or nitrous injected engine is closer to modern production cars than a normally aspirated Pro Stock car.
Old 07-01-2015, 05:56 PM   #37
Rob Petrie E395
Liked 216 Times in 77 Posts
Look at it like this for a minute. Its easy to say kill Pro Stock or change to this or that. When you don't own one or have to pay for the changes. How would we like it if someone decided to kill Stock and Super Stock? After the whole PST deal I think it would take alot for NHRA to kill another class. Especially a Pro class.
Old 07-01-2015, 06:11 PM   #38
boostedf22c
boostedf22c's Avatar
Neither of them are even close to resembling modern production cars.
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 07-01-2015, 06:34 PM   #39
joespanova
Alan , did you actually READ what I said.......read it again. Your reply has zero connection to my post.
I SAID..............PRO STOCK should be small blocks w/ fuel injection and or turbos.
Read my post again.
Leave Pro Mod out of this..........
Old 07-01-2015, 07:37 PM   #40
SSGT Mustang
Liked 204 Times in 54 Posts
Pro Mod is awesome. Pro Stock is not.
Pro Mod represent the roots of competitive drag racing. Run whatcha brung. Different cars, some crazy stuff, some not so crazy, various combination, innovation, and most of all, scary fast and exciting.
Pro Stock used to be great, but not anymore. The fire burned out long ago. It's become pretty much the naturally aspirated version of funny car. What a shame.
For my money, Pro Mod over Pro Stock any day and twice on Sunday.
SSGT Mustang is offline   Reply With Quote
