Old 06-28-2015, 09:41 AM   #21
Stocker 2
Default Re: 2016 Drag Pak
I hope that we're looking at the future of Pro Stock.
You are probably right on target as usual.
Stocker 2 is offline   Reply With Quote
Old 06-28-2015, 09:41 AM   #22
Dick Butler
Liked 32 Times in 19 Posts
Billy,Nees, You are correct. One wt break, heads up but I do not like the fiberglass parts comments. Just another comp car, Pro Stock or Top Sportsman car.
As for any Turbo or Supercharger in a Stock or SS class they only are for one thing.... To confuse the factoring methods even more. Carbs versus Injection is bad enough and very successful confusion of factors...
Yes to the idea of replacing Current Pro Stocks with factory appearing Factory Stock cars.
Old 06-28-2015, 11:13 AM   #23
Liked 1,917 Times in 431 Posts
If you're going to try it, naturally aspirated, two valves per cylinder, cam in block, 440 cubic inch maximum, 400 cubic inch minimum, maximum of two 1000 CFM approved throttle bodies, flat top pistons, maximum 5 forward speeds, back half only, 16"x33" slick, fiberglass hood, with a 6" scoop, 3200# with driver, although 3000#, or even 2800# with driver would be better, if you can get there.
I don't think they'll be fast enough to please the crowds, I don't think NHRA will like it, and I think the whole thing will be out of control in two years or less.
Old 06-28-2015, 02:35 PM   #24
Right Alan, and The Big 3 engine options will all look strangely alike, and it will be boring, for that reason..Sort of like Nascar.
Old 06-29-2015, 12:38 AM   #25
Jeff Stout
Liked 708 Times in 285 Posts
Just curious on cost of 2016 drag pak
Old 06-29-2015, 08:02 AM   #26
Ronnie Hamlin
Liked 29 Times in 8 Posts
$99,426.00 for the 426 naturally aspirated, $109,354.00 for the supercharged version according to what was said at the press announcement.
Ronnie Hamlin is offline   Reply With Quote
Old 06-29-2015, 11:39 AM   #27
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: 2016 Drag Pak
The supercharged motor is 354 CI. Jim
Old 07-02-2015, 04:39 PM   #28
treessavoy
Liked 4 Times in 4 Posts
Will Dodge finance them for 5 years and what kind of warranty do you get?
JimR
Jim Rountree
Old 07-02-2015, 04:53 PM   #29
Jeff Teuton
Liked 325 Times in 50 Posts
You know, an innovative person can finance these if you are a little creative. I am a car dealer first and a banker second. I have helped a couple of people finance these things. The key is they are identifiable by serial # even they have no title. Banks do it daily, use a UCC filing to record your interest in anything identifiable. In many states boats don't have titles, but have serial numbers. Now if you got a beacon score that won't stand a look, your local banker might not help. There is no national across the board program, but your local guy with everything else ok should be able to do it. Kevin and I were in Detroit for the last three days. Impressive cars, fast, going through tests now, Kevin drove one of them. They will both be in Denver. More as it unfolds. Lot of details available, but not here.
Jeff Teuton 4022 STK
Old 07-02-2015, 08:08 PM   #30
H Hoover
H Hoover's Avatar
I think if you can't afford to buy it outright, you may be better off with something less. $100 K isn't that much money anymore.
H Hoover is offline   Reply With Quote
