Old 07-07-2015, 11:21 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default GM Canyon/Chevy Colorado
Seeking feedback on these two vehicles as a tow vehicle.
They can tow up to 7000#. Uses a V6 rated at 305 hp, 6sp auto.
My Impala SS weighs about 4000#, Featherlite 3110 about 1800#
About 5800# loaded up.
Dan
Old 07-07-2015, 04:18 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: GM Canyon/Chevy Colorado
You would be better off with a 5.3L Silverado with the HD tow package. You probably don't need the Max tow package which includes the 6.0L engine. Make sure you get the integrated brake controller, it's a very nice package !
Old 07-09-2015, 06:04 AM   #3
james schaechter
Liked 1,443 Times in 302 Posts
When I was looking in to the max tow, I found that they now offer it with a 5.3 and the 6.2 engine now. I would bet that the 5.3 is close to the canyon in mpg and the overall truck would be much better, especially for towing. Only people I know that actually spec out their trucks that close to the weight they are towing are the salesmen trying to sell the junk they have instead of what you need. I would want something that would easily exceed the need in terms of weight. Don't forget overall weight include fuel passengers, cargo,etc.
James Schaechter 3163 STK
Old 07-09-2015, 10:07 AM   #4
tj310
In 2005 we bought a brand new V6 stick 4wd s10 2door Blazer rated to tow 5000 lbs. I built a smaller light trailer to tow our 2900# Firebird worked out fine, better than anticipated . Lasted 9 years.
It only cost 1/3 of a Suburban , 1/2 of a pickup and you couldn't get a stick in a fullsize ---Trevor
Old 07-10-2015, 12:11 AM   #5
Dan Fahey
Dan Fahey's Avatar
Right now I am towing with a Modified 1994 Caprice Wagon.
Bought a Featherlight 3110 used Trailer.
The Caprice installed 3.08s, new trans, rebuilt rear with New Moser axles, ARP studs and of course all new bearings.
Recently added new HD springs and air bag system with pump.
Complimented with Metro Lower control arms and SS Sway bar.
Going to see how it does going to Pittsburgh.
Handles great!
Engine has 217000 miles and passed Maryland Federal Emissions.
Building a 383 for Towing.
But eventually looking at the GM Canyon.
Sooner or later will have to retire the wagon!
I like it because my wife will find it easier to drive.
The full size Silverado is a beast to park.
My wagon will actually make a U-turn tighter than most small cars.
Dan
Old 07-10-2015, 07:15 PM   #6
Detroit Bob
Liked 8 Times in 3 Posts
Keep in mind that you have to stop that weight as well as tow it. I would be wary.
Bob Kowal STK 345
Detroit Bob is offline   Reply With Quote
Old 07-11-2015, 06:13 AM   #7
joelster
How often do you tow? That is what I would base my decision on. A brand new loaded Colorado 4x4 can be had for around $35k. A similarly equipped Silverado is $10-$15k more. If you tow multiple times a week, I'd get the Silverado. Be careful when you look at them though. There are TONS of LT trim level Silverado's that come with the 4.3 V-6 now.The 5.3 is a $1095 upcharge.
joelster is offline   Reply With Quote
Old 07-11-2015, 03:54 PM   #8
Tom Meyer
Liked 354 Times in 120 Posts
If you are talking about 2015 Canyon /Colorado with the v6 it is a dog compared to the 12 and earlier straight 5 we got both. The 05 pulls a open trailer ok but struggles in the hills. Early models did come with a 5.3 v8, also you want the off road package with heaver springs. Brakes a so so, trailer brakes need to work. Tom
Tom Meyer 5240 SS Stock ???
Old 07-22-2015, 02:29 AM   #9
Adger Smith
Liked 880 Times in 311 Posts
Dan,
FYI.
I have a loaded 2005 HD 1500 (4 door) with the towing package W/ 3.73 gears. I've pulled a lot of miles with an open trailer carrying various loads. Cars, Machinery and Parts. Absolutely no trouble. Panic stopped (With loaded trailer) a couple of times running 70+, no problems. The heaviest thing I have pulled is a large Lagun Mill trailer and mill was about 12,000 lbs. I brought it from Colorado Springs co. to East Texas. The longest loaded pull I made was with a CWT balancer and Sunnen hone from L.A to East Texas. Approx 8,00o lbs loaded. Did it in Aug of 2012. It Was 117 degrees going through Pheonix. absolutely no problems on the trip, except one blown trailer tire. This has been a great truck. BTY it's life time avg mileage for 156,000 mi is 16.2 MPG. Those 1500 HD's W/Tow package are a pretty well thought out combination & good for pulling.
Adger Smith (Former SS)
Old 07-22-2015, 11:33 PM   #10
Dan Fahey
Dan Fahey's Avatar
Originally Posted by Adger Smith View Post
Dan,
FYI.
This is really good information.
The Caprice Wagon uses 3.08 with a 27 inch tall Nitto 255/17/50 tire.
Pittsburgh ProAm mountains was no problem up or back home.
Used Drive and Snuck in the OD on down hill or level stretches.
Going to add a Torque Convert Lock Switch for the clutch.
The real excitement watching the NASCAR travellers tailgating each other to go faster And at times less than a car length between.
Mostly stayed behind Tractor Trailers.
Driving the speed limit which was fine for me.
Added a SS sway bar to the wagon and has nice tight handling.
Towing your situation awareness is heightened.
So far avoided most of the scary insane desperate drivers.
D
Search this Thread:
Advanced Search
