Old 07-05-2015, 07:37 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Cam regrind
Any good machine shops in the Philly and surrounding areas that regrind cams?
House of Darts is offline   Reply With Quote
Old 07-06-2015, 11:08 AM   #2
SGSST109E
Liked 126 Times in 61 Posts
Default Re: Cam regrind
The manufacturers are very reasonable in charges with a quick turn around.
SGSST109E is offline   Reply With Quote
Old 07-06-2015, 11:51 AM   #3
FED 387
Liked 333 Times in 180 Posts
check with the manufacturers also if the cam has been hardened many cam grinders might not want to do the work--- we used a Company in the Carolinas hafta look thru my notes I'll get their contact info--FED387
Old 07-06-2015, 12:45 PM   #4
House of Darts
I'm just trying to see if a stock regrind will be cheaper on my Dime Rocket. Thanks
Old 07-11-2015, 04:29 PM   #5
Bench Racer
Liked 99 Times in 21 Posts
??Possibly Camcraft in Arden,NC
Bench Racer is offline   Reply With Quote
Old 07-11-2015, 04:57 PM   #6
Billy Nees
Liked 7,783 Times in 1,743 Posts
The biggest issue that you're going to run into with a stock regrind is going to be the inability to change the lobe separation. I'm sure that it is going to want to be tighter than stock.
If you do insist on doing one though, I have dealt with Camcraft before. They'll do the best that they can for you!
Billy Nees 1188 STK, SS
Old 07-12-2015, 01:08 PM   #7
GTX JOHN
For our Mopar stuff we found for a Stocker the cam was
one of the worst areas to try and cut corners. The are a significant
part of how well the car performs.
John Irving
741 Stock
741 Super Stock
Old 07-14-2015, 09:38 PM   #8
John Leach
In Baltimore not that far away is Racer Brown Cams 410-866-7660 ask for Jim
John Leach is offline   Reply With Quote
