Old 07-20-2015, 07:48 PM   #1
SSGT Mustang
Liked 204 Times in 54 Posts
Default Aftermarket Steering Column
I have one for my modified car that I installed but the thing bolts together. There's a bolt for the quick disconnect and a bolt at each u-joint mount. The manufacturer said that that's how everyone does it, and that welding isn't required but that scare the heck out of me.
Anybody have any experience with this? The car weighs 2950.
Thanks.
SSGT Mustang is offline   Reply With Quote
Old 07-20-2015, 08:04 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 697 Times in 202 Posts
Default Re: Aftermarket Steering Column
Not sure what it looks like but my S/G car had a bolt at the u-joint and the NHRA tech just made sure it was safety wired. (It was a thru bolt with a nut)
Old 07-20-2015, 08:40 PM   #3
SSGT Mustang
The shaft is 0.125 wall chromoly. The quick disconnect is drilled for a 1/4 stainless bolt, and the u-joints that connect the shaft to the rack are drill for the same.
Old 07-20-2015, 08:53 PM   #4
jackarnew
Thanks.
Be safe and install at least 1 5/16 inch allen set screw in each slip joint long enought to lock with a nut on top. I always use 2 set screws per connection. Know of colums seperating at connections (U JOINTS)during a run as car launched. I was their and saw it happen. Driver must have been holding on to wheel for suport and pulled it back as car moved forward. Luckey he was no going too fast at the time an stopped. If you use only a thru bolt grade 8 or better with a locking type nut and only SAE thread. Be sure that drill size is a tight fit for bolt or you will have play in stearing.If any play install 1 set screw at each thru bolt 90 degreas off from drill hole.
jackarnew is offline   Reply With Quote
Old 07-20-2015, 09:07 PM   #5
SSDiv6
Liked 1,604 Times in 583 Posts
I have the bolt-on type and used an aerospace close tolerance AN bolt and AN self-locking nut. If you can provide the diameter and length of the bolt, I can give you the aerospace AN numbers you will need to get.
Old 07-20-2015, 10:13 PM   #6
SSGT Mustang
Thanks guys. The bolts are 1/4" diameter by 1 1/2 " long not including the head.
Good idea about the set screws.
Old 07-20-2015, 11:09 PM   #7
SSDiv6
Sorry, should have been more specific.
Need the grip length; from the end of the head to where the threaded portion starts.
Old 07-21-2015, 09:33 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
I welded the joints on mine except for the connection to the steering box. The kit I used had a split collar to keep from pulling back on the column. It was a Jegs kit.
Mike Pearson 2485 SS
Old 07-21-2015, 10:13 AM   #9
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
In addition to the AN bolt, I've seen washers like this used to spread the load over a larger area and keep the tube from collapsing. It also seems to me that it would be beneficial to have a solid section of shaft where the u joint is bolted (with some sort of plug inserted into the column). Not sure if this would be overkill or not.
https://www.pegasusautoracing.com/pr...oduct=3077-003
3207 D/SA, C/ED
Andrew Hill is online now   Reply With Quote
Old 07-21-2015, 12:30 PM   #10
SSGT Mustang
Thanks a bunch. That's great information.
I was actually thinking about welding in a bolt tube inside for each bolt, but forgot about that.
Thanks to each of you.
