Old 07-24-2015, 11:44 PM   #81
HR9121
HR9121's Avatar
Default Re: Why Class racing dies slowly
Stop the insanity!
James Williamson
W200 J/SA. SS/JA
Old 07-24-2015, 11:57 PM   #82
randy wilson
Liked 22 Times in 22 Posts
Originally Posted by SStockDart View Post
$7,000 engine out run a $28,000 engine....really????
Yes, really. The breakdown on the $7,000 engine.283, .090 over, $600 honed and lifter bores bushed, high-tech dual plane, $250 dollars, port work, $100, 29 year old Pistons bought from Rick Katterjohn, and lightened by Rebco, $500, stock rods finished by Al Parker, $200, stock 283 crank, and balancing, $300, used Moroso oil pan, $100, dart 200 cc heads, angle milled, and valve job by Al Parker, $1,200, cam by Comp, $275, roller lifter by comp, $300, cloyes hex-a-just, $150, Howard rocker arms, $250, push rods, $100, used stud girdle, $100, total seal rings, $300, bearings, and gaskets, $300, super sucker spacer, $100, z28 oil pump, $25, ATI steel dampener, used, $150, used water pump, $50, used 1 and 7/8ths headers, $150, damn best 750 cfm $1,200. Misc. $300. I know because I assembled it. Don't know the breakdown of the other engine, but it was to be the hot item. And it did run.
don,t have one
Old 07-24-2015, 11:58 PM   #83
Mike Jones
Liked 684 Times in 289 Posts
Stop the insanity!
Car count in Denver after Q2: S - 34, SS -16...
Mike A114
P/SA
Old 07-25-2015, 12:02 AM   #84
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Nice job, congratulations
Old 07-25-2015, 12:13 AM   #85
HR9121
HR9121's Avatar
Mike A114
P/SA
Afraid Denver is not an indication on the pulse of sport as it always has low car counts. Columbus divisional 102 stockers 79 super stock.
James Williamson
W200 J/SA. SS/JA
Old 07-25-2015, 12:18 AM   #86
randy wilson
Thank you. It actually was a shock.
don,t have one
Old 07-25-2015, 09:42 AM   #87
Dick Butler
Liked 32 Times in 19 Posts
Gentlemen, I appreciate the place to discuss my view of Racing Class in Stk and SS.
There is a place for every type of racing in these eliminators.
I appreciate all your input and opinions. I appreciate you listening to my thoughts.
Lets end this discussion with a hand shake and a thank you at this time.
Good Luck and I hope to see you all at the races..
Dick Butler
Old 07-25-2015, 06:34 PM   #88
mtkawboy
Liked 54 Times in 18 Posts
As far as crate engines go in stock cars if you have the money & know the right people you can buy the special head bolts & intake bolts that cant be duplicated . So why would that work in NHRA any better ? If you have claimer engines the guy with the money just keeps buying the fast guys stuff until he gets tired of building new engines.
mtkawboy is offline   Reply With Quote
Old 07-26-2015, 06:24 PM   #89
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
Who Builds a car for just for class racing and not for the bracket part of it ?
Jake Biermann
Old 07-26-2015, 08:44 PM   #90
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Just left the divisional at Columbus... Final was heads up in Superstock with at least 2 other heads ups in the 3rd and 4th rounds...If you built a motor for the " Bracket " part of it ....you left early .
Jeff Niceswanger 3740 SS
