Old 07-24-2015, 09:55 PM   #1
ollucky
Default Need Help with Landrum Front Spings
Just installed Del A Lum Bushings, and Landrum 180 lb front springs on a 69 Camaro. The front end weighs 1667 lbs.
Problem: car sits up with the front end fully extended...if i under stand spring rate correctly it takes 180 lbs to compress the spring 1 inch. If so each front wheel has 833 lbs of weight divided by 180 lbs of spring so it should come down 4.63 inches?
Please Help
Mark
210 392 9902
ollucky is offline   Reply With Quote
Old 07-25-2015, 11:19 AM   #2
ollucky
Default Re: Need Help with Landrum Front Spings
New Spring is about 4 inches taller the stock spring that came out of it. Does anyone know spring rate of a factory 69 camaro?
Old 07-26-2015, 12:15 PM   #3
Geerhead55
Liked 5 Times in 5 Posts
Smile Re: Need Help with Landrum Front Spings
There were different spring rates on '69 Camaros,, from 6 cylinder cars right up to iron headed big blocks. I'm sure a Moog catalog or other similar suspension catalog can show you the info you need. My 2 cents.
Danny Durham
