Liked 288 Times in 109 Posts
Racers,
I am considering a high amp rated continuous duty solenoid as my master switch. Anyone have experience with doing this? In my situation it will be for weight saving reasons. I have the Super 10 on a weight reduction plan and removing the hardware that allows me to operate the cutoff switch while seated and from the rear will remove about 7 pounds. |
#2 | |
Liked 1,948 Times in 589 Posts
Mike Pearson 2485 SS |
#4 | |
I fully agree. KISS
Ed Wright 4156 SS/JA |
Liked 129 Times in 59 Posts
I'm guessing you have a battery(s) mounted in the bed on the S-10? Using a continuous-duty solenoid to replace a Cole-Hersey style master cut-off switch would require you to run power to a toggle-switch of some kind inside the cab of the truck, somewhat defeating the purpose of the master-switch disconnecting all power at the battery. Better to have one mechanical disconnect at the rear for safety's sake.
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 372 Times in 130 Posts
I could see it working with this type of rear starter solonoid system.
Might take a little more creative wiring than what is in the pic to work as "all kill" switch tho. ![]() Last edited by ALMACK; 07-27-2015 at 10:14 PM. |
Almack, I do not run an alternator.
Liked 237 Times in 126 Posts
How about a transbrake style solenoid rigged to the backside lever on the cut off where the Morse cable is? Power it off the battery with a normal off momentary switch in the cabin. Punching the switch would only preform one operation, but "Turn the darn thing on" is the main use of the cable lever.
Remember NHRA says one switch in the kill circuit only. Dale
Liked 162 Times in 45 Posts
I see two problems with this idea. First I dont believe a solonoid exists that will hold up in this application. But more importantly, in one of the two rule books it specifically says this is illegal. It may be in their big book that we dont get to see very often.
Liked 81 Times in 45 Posts
We use a older Dodge diesel solenoid in our race car. It is the round type and we bought it at NAPA. I believe it was listed as a battery relay and was rated about a 100 amps. Hope this helps.
Kirk |
