Looking for a kit. Wanting to remove the booster from the Monte. Where can I find a kit with plate, push rod, and master cylinder, that's easy to install
Look at the "Under the Index for Under a Grand" thread. Quick and easy AND safe. BTW, I never even took the orig. MC off of the car.
I took a m/c off an '81 Chevy truck with manual brakes (aluminum / plastic) with the pushrod and pushrod retainer, had to fab up the mount plate and customize the rod length, no differential valve at all, works well.
Whatever you do, don't forget to positively retain the m/c push rod. About $40 for a new m/c once I fitted it all up. |
Liked 333 Times in 180 Posts
Go to Advance Auto Parts --- part number 10-1737 1978-1987-G body MANUAL BRAKES master cylinder--- $26.49---FED 387
#5 | |
I did one like this back in about 1985. Never had a problem. You could drill the hole in the piston deeper and use a longer rod, if it makes you feel better, but not necessary if you use a retainer and WELD it all together. No threaded adjusters I don't believe you will need to buy a manual m/c. Made it even easier: http://classracer.com/classforum/sho...t=44903&page=3 ![]()
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 08-01-2015 at 02:38 PM. |
