Old 07-30-2015, 05:13 PM   #1
hemid68
hemid68's Avatar
Liked 8 Times in 7 Posts
Default Do grade points go with the driver or the car?
I wondered if the grade points go with the driver, or the car? Can grade points from a lower class, say SS/H, be used for a higher class?
Example, can the grade points for a say SS/H be used to enter a SS/AH, at a national event?
Thanks,
Dan
hemid68 is offline   Reply With Quote
Old 07-30-2015, 05:24 PM   #2
Bill Koski
Bill Koski's Avatar
Default Re: Do grade points go with the driver or the car?
The points go with the driver. Points can be used to run any eliminator not just the one they are earned in, SS points can be used in Stock, SC, SG and so on.
Bill Koski is offline   Reply With Quote
Old 07-30-2015, 05:31 PM   #3
REGGIE WINKLES
Liked 39 Times in 9 Posts
A driver retains their points in a given eliminator, lets say Super Stock.
That driver can enter any class with the Super Stock eliminator and earn
points. Be sure at tech to let them know what division you would like the points to go to.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 07-30-2015, 07:38 PM   #4
G Schenck
Liked 81 Times in 35 Posts
Reggie, he is asking about grade points.
Greg
G Schenck is offline   Reply With Quote
Old 07-30-2015, 07:49 PM   #5
HR9121
HR9121's Avatar
The car owner also earns points if the owner is different than the driver. Here's an example, you own the car and have a driver for it and he earns 4 grade points. You can enter the car using his grade points as long as its the same car and he is not entered in that eliminator. He must have listed you as the car owner on the tech cards at the points races he entered driving your car and it still has to be approved by the division director.
James Williamson
W200 J/SA. SS/JA
Old 07-31-2015, 09:40 AM   #6
MadMax404
Its essentially one or the other like stated above. Driver can earn points or owner can earn points, whichever is designated at the event per the driver's tech card.
Grade points are earned via eliminator not eliminator "class". Unless this has changed in 2015 you can only use grade points on a higher eliminator not a lower eliminator.
I.E a Stock elimintor driver can earn stock points at divisionals and use them for Super Stock at a National Event however a Super Stock driver at a divisional cannot use them for Stock at a national event. This was the rule in 2013/14 as I used my Super Street grade points in Super Gas and Stock but I could not use my Stock grade points in Super Street.
Mad Max NHRA/IHRA Stock 4040
Mickey Thompson Tires;Mothers Polish; Champion Brands Oils
MadMax404 is offline   Reply With Quote
Old 07-31-2015, 09:49 AM   #7
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
You can use super stock points to enter stock, the only exception to the rule is super street. You can only use super street points to enter national events in super street. I've earned points in everything from Super Gas, stock, super stock and super comp and I have used those points to enter other category's.
Chuck
C and W Racing is offline   Reply With Quote
Old 07-31-2015, 09:43 PM   #8
hemid68
hemid68's Avatar
Thanks guys for the answers to my questions. It is much appreciated.
Thanks again,
Dan
