#11 |
Liked 37 Times in 33 Posts
I use Amsoil Severe Gear Sae 75W-110 Synthetic Extreme Pressure Lubricant. It's a premium grade extreme pressure (EP) lubricant engineered specifically with "High Film Strength" for high load demands.
It's also compatible with conventional and synthetic gear lubes and most limited slip differentials. Plus it's recommended for applications requiring 75W-110, 75W-90, or 80W-90 gear lube with any of the following specifications: API GL-5, MT-1, MIL PRF-2105E, Dana SHAES 234 (Eaton PS-037), Mack GO-J, or the differential gear lube specifications from GM, DaimlerChrysler or Ford. |
#12 |
Liked 520 Times in 132 Posts
Redline heavy duty shockproof in my Dana no problems.
#13 |
Same here, (and light shockproof in the Jerico)
#14 |
Liked 1,018 Times in 217 Posts
We run all Strange products with Royal Purple. Never had an issue. (Knock on wood)
Brett Candies 4192 Stock/SS God Bless America |
#15 | |
Sponsor
Liked 9 Times in 1 Post
Switch to the Driven's Speedway Synthetic oil in Challenger and have always ran in COPO with no issues. Its VERY light..... I do break in for 3-4 passes with No Synthetic Driven Break in or Torco oil from Mark Williams. As far as an A to B to A test - never done - doesn't matter since I won't run a light weight non synthetic in the rear or trans anyway - we have enough other **** to test when we go out! |
#16 |
Amsoil Severe Duty for me
#17 |
Liked 133 Times in 76 Posts
My opinion, your results may vary.
Conventional gear oil, cheap and readily available and designed for rears. So cheap that changing it every year is a no brainer. I install rare earth magnets in engine,trans and rear to catch any wear particles which is what wears out gears and bearings. Drain,clean and refill and your rear will last. Synthetics are usually thinner and will flow well, also made to withstand heat which drag cars usually don't see. Cost more but you're only using 2 quarts so it's not a bank breaker. Possibly a little better lubrication and possibly worth the peace of mind but not necessary on a drag car. Shockproof doesn't make any sense to me. thick as mud and it's claim to fame is it clings, so does axle grease! Might be great in a roundy round car where the rear gets very hot. I want thin oil that flows all of the time. |
#18 | |
![]() 6383 SS
Shawn Blair 6383 SS 634 STK Last edited by Shawn Blair; 08-02-2015 at 12:46 AM. |
#19 |
Liked 240 Times in 112 Posts
This is my first go around with Redline in the diff.. Using super light shock proof, I'm @ 3650 w/me but I'm slow. 5.14's in a 9".
Dave Noll, EF/S ,?/SA 6526 |
#20 |
I have to assume that you have not used the light or heavy Shockproof gear oils offered by Redline. It is not at all thick, I`d guess it flows like a 30W engine oil, and it definatly does cling. A couple of years ago, I pulled the cover of my Mustangs 8.8" rearend after sitting all winter, and the top of the casting was still wet with oil. Both my cars are 4 speeds, and I use the Redline light shock in the Jericos, and the heavy shock oil in the diffs. My 10.0-9.9 ET bracket car has a Dana 60, and and has been a stick car for 15 years now, the gears always look like new. I think some gear ratios are more likely to break than others, especially when you get into lower ratios. I`ve been racing my Mustang for 13 years now, the same set of 4.88s still look fine, but I have broke 2 sets of 5.14s, which have 1 less tooth on the pinion than the 4,88s do, From what I have seen with 8 3/4 MoPars is that with the steeper ratios, the teeth on the ring gear get quite shallow, which can`t be good for strength.
