Old 08-04-2015, 10:56 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,388 Times in 504 Posts
Default Shutting car off while in gear
I can't ratchet up to neutral through the finish line. Is it safe to shut car off while in third gear through the traps? Will that stop the pump and lose lubrication in the trans? I want to check all the plugs after a run.
'65 Mustang SS/L & L/SA
Old 08-04-2015, 12:13 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Shutting car off while in gear
Bobby,
I do not know the solid answer but to me, it seems like a potential problem. I have visions of the pump pressure slowly bleeding off and causing what ever clutch pack is engaged to slip. A one time deal might be OK ??
In my opinion, I think your plug reading would be acceptable to just stop as quickly as practical and switch engine off as you near a stop.
Larry Woodfin 471W
Old 08-05-2015, 09:21 AM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
Bobby, would be best I think to contact whom ever built your trans and run it by them first.
Joe Buchanan SS/BX 3117
Old 08-05-2015, 10:13 AM   #4
SSGT Mustang
Liked 204 Times in 54 Posts
Bobby,
Congratulations for making it to the final at Atco last weekend. Great driving, and a close race.
Don't know what you have for a shifter, but the quarter stick shifts very easy from 3rd to neutral in a C4 with a reverse pattern. Pull back the lever and push right up. I had one for years before going to a PPP pneumatic shifter in my super stocker.
Another solution would be to call Joel's for a valve body with an electric neutral. I've heard mixed reviews about them, but I think that they make the only clean neutral valve body for a C4. I'm probably going to go that route too, since shifting back from 3rd with the PPP leaves something to be desired. You're almost waiting for that moment when it gets hung up in the pattern, and you don't reach neutral.
Good luck.
SSGT Mustang is offline   Reply With Quote
Old 08-05-2015, 10:59 AM   #5
gmeyer
Liked 35 Times in 16 Posts
Clean "N" valve body will be the best and safest investment you can make
Call Joels he will set you up 248- 446-6024
gmeyer is offline   Reply With Quote
Old 08-05-2015, 09:28 PM   #6
HR9121
HR9121's Avatar
Wouldn't it just be safer to switch to a forward pattern valve body?
James Williamson
W200 J/SA. SS/JA
Old 08-05-2015, 09:37 PM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Might be off base but would it work to use a wide band o2 and record somehow it's readings over the 1/4 mile. Even w a go pro videoing it
chris ok is offline   Reply With Quote
Old 08-05-2015, 09:46 PM   #8
btrc
Liked 84 Times in 42 Posts
We have one of Joel's electric neutral setups and it works great. In fact I probably use it more than I should. Return road etc.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 08-05-2015, 09:55 PM   #9
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
I asked the same question to someone I consider an expert and his opinion is that the neutral on a forward shift is a natural neutral but not a "clean neutral. Something about the path of the fluid in a natural neutral is totally different from a "clean neutral". He has both types of valve bodies and still recommends the clean neutral for shifting on the top end. I bought the clean neutral one for myself. Even though I had to purchase a new shifter also. Oh the PPP is now my shifter of choice.
Mack Reeves
2377 STOCK & SUPER STOCK
Old 08-05-2015, 10:46 PM   #10
HR9121
HR9121's Avatar
Thanks, I didn't realize this. I guess I better ask my transmission guy some questions.
James Williamson
W200 J/SA. SS/JA
