Im sure this has been asked before but what sixe wheel should i buy for a 69 nova stocker to run a 30 by 9.
damn auto correct
If I remember correctly, I ran a 15 x 8 with 5.5" backspace to clear a 30 x 9. I also ran a very minimal spacer (1/8") on one side to center it in the space available.
Tim
SS/MA 5017 |
great, thank you and I will from now on.
Liked 799 Times in 236 Posts
On mine, a 9" wheel with centered backspacing (4.5") fits perfectly.
"That'll never work....." |
Do all wheel manufactures make a 9 inch wheel?
8's and 10's are the most common sizes. Companies like Bogart, etc. will make any width you'd like. Weld makes their Pro Star in a 9" width with a centered b.s. that would make a nice wheel without going the 'custom' route.
http://www.jegs.com/i/Weld-Racing/92...oductId=746350
That is awesome thank you
Liked 33 Times in 16 Posts
Champion wheel will make you what you want with backspacing in 1/4" increments. Light, look great and reasonably priced. http://www.championbillet.com/
Rich Taylor I/SA - 321 |
Liked 54 Times in 27 Posts
Backspacing is generally done from the edge of the wheel to the mounting surface, so it includes the thickness of the rim from the tire to the edge, usually about 1/2 inch. So, zero offset on a 9" wheel would mean a backspace of 5".
