Old 08-18-2015, 07:06 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default EFI TROUBLE! ED W. All Cooters, Help!!
Took my car, '92 Camaro J/SA, out to our local track on Aug.2, ran 11.54 and 11.52 @ 114.00. Air 2400 ft. Density 28.97 Humidity 55%.
Go to the same track on Aug.16, 2400 ft. Density 29.03 Humidity 77%,
and car goes 11.84, and 11.82 @ 106.00. Changed nothing but the oil.
Leaked it yesterday, perfect! RPM @ the finish line the same and A/F
Ratio @ the finish line the same. I am lost. All help welcome. J.R.
J.R. Haddad is offline   Reply With Quote
Old 08-18-2015, 08:40 PM   #2
Liked 1,888 Times in 423 Posts
Default Re: EFI TROUBLE! ED W. All Cooters, Help!!
Why are you assuming it is an EFI problem?
Old 08-18-2015, 08:52 PM   #3
J.R. Haddad
Alan, you're right, I should not have jumped to that conclusion. It's just
that I'm a Quadrajet and sometimes Holley guy, and the EFI and this problem have me baffled. J.R.
Old 08-18-2015, 09:46 PM   #4
Ed Wright
Ed Wright's Avatar
I would be surprised if it's an EFI problem.
What system do you have?
Using a data logger?
Ed Wright 4156 SS/JA
Old 08-18-2015, 10:12 PM   #5
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: EFI TROUBLE! ED W. All Cooters, Help!!
I'd check the rubber brake line hose at the rear end housing.I've had 2 that all of a sudden would let fluid through under pressure but internally had collapsed and wouldn't let the pressure release. Same symptoms on our car as yours.Hope you get it fixed fast without a lot of trouble.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 08-18-2015, 10:12 PM   #6
Compare incrementals and see where you are off.
If your A/F ratio and RPM are the same, odds are your timing is as well.
If your RPM is the same, but your MPH is low..................
The humidity is 22% higher on the slower pass.
What change did you make with the oil (and filter)?
Old 08-19-2015, 12:25 AM   #7
J.R. Haddad
Incrementals- 60- 1.48-1.53
594-6.75-6.92
660-7.24-7.42
1000-9.55-9.79
1320-11.52-11.82
The 330's were not working either day. Thanks so far guys, J.R.
Old 08-19-2015, 12:36 AM   #8
J.R. Haddad
Alan, oil was Mobil 5-30 and stock filter G.M. A.C. Delco before and after,
no changes on either. I try not to introduce any variables unless I'm at
the track while I'm sorting out this new to me combo. J.R. Ed, Datalogger
is an Accel Gen.7. I am able to download it, but cannot get graphs
lately. J.R.
Old 08-19-2015, 06:39 AM   #9
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Did you measure the amount of oil you drained out? Maybe it is carrying more now,
If it has the same RPM but lost 8 MPH then it about has to be in the converter.
Pedigo Perf is offline   Reply With Quote
Old 08-19-2015, 08:53 AM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
I would shy away from any AC Delco filters. I had several collapse due to plastic internals. Cost me an engine. Check the filter it could be collapsed. Now I run a System One reusable filter. No more passenger car filters or oil.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
