Old 08-25-2015, 08:54 PM   #1
Biscayne
Biscayne's Avatar
Liked 2 Times in 2 Posts
Default What are the best casting double hump heads?
Looking for the best casting # early style double hump heads? 461? 462? Thanks
Scott
Scott Chalk 1226 I/SA
Biscayne is offline   Reply With Quote
Old 08-25-2015, 09:18 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: What are the best casting double hump heads?
461X were the heads everyone looked for years ago..
Intake runners were bigger than most all other heads.
Casting quality was not very good on some of those old heads.
Head bolt bosses cracked and the material the heads were cast from seemed soft and not as durable as later heads....
Rich Biebel
S/C 1479
Stock 147R
Old 08-25-2015, 09:37 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
the 041 casting is a good choice, in addition, it has bolt holes on each end that can be helpful with mounting a bracket or such.
Larry Woodfin 471W
Old 08-25-2015, 09:45 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
The best flowing "untouched" heads out of the 39 sets I have tested were particular 462 and 291 castings. I did not flow 461 heads because they were not legal on my combination. I flowed 462, 291, 292, 186, 041 and 492 castings. 186 and 041 always showed good numbers. You had to be picky about the 462 and 291 castings.
For what it's worth. I'm sure there are others with more data and experience.
Old 08-25-2015, 10:24 PM   #5
Biscayne
Biscayne's Avatar
Thanks for the info guys
Old 08-25-2015, 10:25 PM   #6
Dragsinger
The late Dave Layer like the 291 casting. Hettler likes the 041 casting. But this is when doing SS modifications.
Larry Woodfin 471W
Old 08-26-2015, 12:14 AM   #7
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: What are the best casting double hump heads?
I assume you are running a '68 327/275 or a 350/295. I have several cores around, and it seems that most cores out there aren't very original, that is, they have had too many valve jobs, guide replacements, and re-surfacing done on various places that would carry the original design a bit far from the original configuration. In short, low mileage virgin cores with no rebuilding or modifications are a scarce commodity. This is by no means restricted just to Chevrolets,either. Now, how do we adequately reconcile all this to some degree of legality and consistency with legality.We all know that mass produced parts do vary, and that is the reason one person's 291 head will outflow another's 041 head,this being within the same blueprint spec.Flowing 39 sets of heads would give a head guy a pretty good idea of what is out there, and a good feeling for whatever variations you could expect.
Old 08-26-2015, 12:39 AM   #8
HP HUNTER
Liked 373 Times in 129 Posts
Non bolt hole fuelies, 291 would be best, bolt hole fuelies, 492 186 041 in that order.
Old 08-26-2015, 09:07 AM   #9
Biscayne
Biscayne's Avatar
I'm looking for a set of non bolt hole, early style heads. Casting number not important. Want a set of stocker prepared heads . Let me know if anyone has a set. Thanks
Old 08-26-2015, 11:53 PM   #10
Mike Jones
Liked 684 Times in 289 Posts
There is a posting in classifieds of a set of 461X heads for sale.
Hope it helps you.
Mike A114
P/SA
