Old 09-14-2015, 09:02 AM   #1
Dell Edwards
Send a message via AIM to Dell Edwards
Default Quick-Time with McCleod Clutch
Hey guys, Has anybody ran across a clutch arm clearence problem? It is rubbing on the face of the clutch itself. I have the longer throwout bearing but I'm using the stock clutch arm. First time fooling with the adjustable clutch. Don't see how the stock arm is going to work. Is there an aftermarket arm that works better? Small block Ford 302 with TKO600. Got every thing else ready and then this happens! Always something!
Thanks!
Dell Edwards is offline   Reply With Quote
Old 09-14-2015, 09:33 AM   #2
Aaron Allison
Liked 150 Times in 43 Posts
Default Re: Quick-Time with McCleod Clutch
Call Ross McCombs at Quick Time. He is very good and offering suggestions to fix issues like this.
(641) 660-2807
Great Guy. Always willing to help.
Aaron Allison 395 STK, 395 SS, 3395 SC
Aaron Allison is offline   Reply With Quote
Old 09-14-2015, 09:37 AM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Check out Lakewood # 15525, it has a notch cut out to clear the pressure plate, also, McLeod makes an adjustable throw-out bearing that might help.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 09-14-2015, 10:46 AM   #4
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
If you haven't already changed the pivot ball to an adjustable one, that's what I had to do when I had the same issue with the QT bell. The pivot that came with the bellhousing was protruding too far forward.
Paul Merolla is offline   Reply With Quote
Old 09-14-2015, 11:33 AM   #5
joespanova
Liked 13 Times in 11 Posts
Yeah , this.....should work. Mine rubbed too.
Old 09-14-2015, 01:05 PM   #6
Dell Edwards
Thanks, I do have the adjustable pivot and I'm rubbing on the other side. I have it as close as i can get it to clutch without a rub but when I press it I get a rub on the other side. How much travel does it need for the actual fingers to release the clutch? Gonna call this guy with quicktime and see what he says.
Thanks
Old 09-14-2015, 01:28 PM   #7
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
You need this^^^ I believe this also extends the fork an additional 1-2" out of the bellhousing to allow the cable to not interfere with the fork opening.
I have the shortest TOB in my Bellhousing and the pivot ball is at the shortest length to the point the fork has came off the pivot ball and ruined levers on the clutch. You need 2 things with a clutch, air gap for the clutch to PP and air gap for TOB to lever. It' can be a balancing act, as one effects the other with a pull cable setup. With linkage you can change the ratio easier, with a cable not so much. I do not know what McCleod recommends on the air gap, generally .250" is normal there are some other variables to, do you have counterweight levers? The more CW the more you need to make sure you have adequate air gap on the clutch to PP. Just some random quick thoughts.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-14-2015, 08:15 PM   #8
Dell Edwards
Thanks Sean, that's exactly what I need! Appreciate it.
Old 09-14-2015, 08:29 PM   #9
Dell Edwards
You to Jerry!
Old 09-17-2015, 05:20 PM   #10
Jerrid Halvorsen
Rob Youngblood told me that quick time bells have a thicker flange that trans bolts to, so it moves the pivot ball much closer to the clutch.
Jerrid Halvorsen is offline   Reply With Quote
