Old 09-22-2015, 08:54 PM   #21
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Rochester 2GC info
Both were stick cars.
Was there anything else back then??
Old 09-23-2015, 10:12 AM   #22
Ed Wright
Ed Wright's Avatar
Powerglides. Robert "Hutch" Hutchison was one of the first I remember making one fast in Div 4.
Personally, I broke a lot of 3 speeds in my '56 around that time. Took me a while to get my head out, and soften up the clutch.
Ed Wright 4156 SS/JA
Old 09-28-2015, 10:49 PM   #23
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Anyone have an opinion on whether to use the power valve in these or block it off. I have a Deano carb and it is blocked off, haven't tried to 'restore' it to a power valve setup.
Mike Moller
NHRA 203 Q-R-T/SA
Old 09-28-2015, 11:49 PM   #24
Mike, How high are you foot braking it?
Old 09-29-2015, 12:25 AM   #25
MikeMoller
MikeMoller's Avatar
Bad air 3000, good air 3500. By the way, just installed Kenny's converter today. With the old converter, 3500 was really wanting to push the brakes. Car was .04-.06 slower at 2500.
Mike Moller
NHRA 203 Q-R-T/SA
Old 09-29-2015, 12:27 AM   #26
NORMAN BARNARD
Liked 2 Times in 2 Posts
Mike, you'll go nut's trying to use a pv in a roch. 2gc carb as they had so many deravations of the pvrc they used.. Plug it, retap the jetting holes and use the holley jetting, better selection and easily obtainable. Tip:, now your ready to begin playing with the fuel curve !!!!!!! (assuming you have a good wide band data logger).
NORMAN BARNARD is offline   Reply With Quote
Old 09-29-2015, 12:30 AM   #27
I don't think you need to worry about a power valve then.
As long as it drives around the pits okay...
Old 09-29-2015, 12:37 AM   #28
MikeMoller
MikeMoller's Avatar
No issue in the pits. Thanks. Will know this weekend if the converter helps- it should be a little looser.
Mike Moller
NHRA 203 Q-R-T/SA
Old 09-29-2015, 09:43 AM   #29
Ed Wright
Ed Wright's Avatar
We used to do that to the old 4GCs. We were told then that we could not remove & plug it. Many of us pulled the piston/spring, pushed the piston up, and put a ding in the rod with a pair of dykes so it could not extend again, and jetted up. Easy to find Rochester jets back then.
Old 09-29-2015, 12:12 PM   #30
MikeMoller
MikeMoller's Avatar
Found a good source of 2GC part including jets-Mike's Carburetor Parts. Has everything for 2GC's.
http://www.carburetor-parts.com/Rochester_c_31.html
Mike Moller
NHRA 203 Q-R-T/SA
