Old 10-02-2015, 08:11 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default radial tire " wobble" video
Larry Woodfin 471W
Old 10-03-2015, 07:09 PM   #2
grncpe
Liked 44 Times in 10 Posts
Default Re: radial tire " wobble" video
Originally Posted by Dragsinger View Post
At 1.07 it looks like went over a hump or something in the track. Right after that the radial roll started, & got worse from there.
Tommy Baker SS/GA # 172
E/SA # 1272
grncpe is offline   Reply With Quote
Old 10-03-2015, 08:33 PM   #3
Dragsinger
a number of things have been suggested and I am following up on all of them.
"If" can work out the logistics we will be at the Noble OK Lucas race with bias tires mounted.
Will post updates.
Larry Woodfin 471W
Old 10-03-2015, 08:49 PM   #4
bigfoot584
https://en.wikipedia.org/wiki/Scrub_radius
This is also something to check if your wheels are to close to
neutral or in set you best have very good front end parts.
This is something street rodders deal with a lot with straight
axles, just replace the wheels with more offset and their fine.
bigfoot584 is offline   Reply With Quote
Old 10-03-2015, 08:55 PM   #5
Dragsinger
Big,
per super stock rules it has factory front suspension [ "A" arm style system, same system as the G body Malibu, Cutlass , Regal ]
Front wheels are 4" wide and centered.
Larry Woodfin 471W
Old 10-03-2015, 09:02 PM   #6
bigfoot584
It still applies you need to imagine a line though each
ball joint to the road surface, it make no different if it's
straight axles , a-arm w/ball joints or McPherson stud
it still applies.
Old 10-03-2015, 09:14 PM   #7
FINESPLINE
FINESPLINE's Avatar
Assuming you are using radial slicks ( as the car is an auto ) , are the front tires radials also ? radials and bias ply tires don't play together well !
FINESPLINE is offline   Reply With Quote
Old 10-04-2015, 12:48 AM   #8
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
The Hemi guys were having that problem a ways back, anybody know if they found a solution?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 10-04-2015, 11:26 AM   #9
Ed Wright
Ed Wright's Avatar
That is one handsome dude in the other lane. You could almost call him pretty.
Ed Wright 4156 SS/JA
Old 10-04-2015, 08:04 PM   #10
Dragsinger
Ed, we make a good pair of olden dudes
Larry Woodfin 471W
