Old 10-08-2015, 04:18 PM   #1
doglover44
doglover44's Avatar
Liked 491 Times in 229 Posts
Default SS Modified
What makes a SS car to fit in the modified class ?
Jake Biermann
Old 10-08-2015, 05:04 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: SS Modified
Modified motor!
SS is HP to weight, SS Mod is cu in to weight.
I'm running a "hand me down" comp motor. Trying like hell to get it on the track.
Chevy55 is offline   Reply With Quote
Old 10-11-2015, 11:27 PM   #3
LethalRat
Liked 4 Times in 3 Posts
Would a 300" Small Block Chevy with the Dart Buick Heads fit into any Super Stock Class? This is an old comp motor.
LethalRat is offline   Reply With Quote
Old 10-12-2015, 08:43 AM   #4
SSDiv6
Liked 1,603 Times in 583 Posts
Yes, it would fit in any GM application depending on the number of carbs.
Old 10-12-2015, 02:17 PM   #5
Paul Hellenberg
Also the Heads castings maybe an issue. Good Luck
Paul Hellenberg
3881 SS and STK
paul@hellenberg.us
Paul Hellenberg is offline   Reply With Quote
Old 10-12-2015, 04:45 PM   #6
david ring
david ring's Avatar
I think it would, but contact the D1 tech director, Ryck Campbell to be sure.
david ring is offline   Reply With Quote
Old 10-12-2015, 07:31 PM   #7
Chevy55
Banned
SS/ Modified, C/M thru F/M, all heads must be NHRA accepted, 2 valves per cyl. OEM casting with OEM # cast in head.
NHRA rulebook, sec11F page 23.
Old 10-12-2015, 08:26 PM   #8
SSDiv6
The Buick Dart head is an accepted cylinder head.
The head was manufactured by Dart for GM with a GM part number.
It is still a great cylinder head for small CID engines like yours.
You can run in SS/BS, with one carburetor, or, SS/CM thru SS/FM with two carburetors.
Old 10-20-2015, 10:46 PM   #9
LethalRat
Thank you guys. What would I have to weigh with that 300" motor and an automatic in SS/EM and SS/FM?
Not sure how the percentage for the automatic works when it says 11.50-12.49 ect.. Do you go off of 11.50?
Old 10-20-2015, 11:04 PM   #10
SSDiv6
Based on 300 CID:
SS/EMA: 3277.5 lbs
SS/FMA: 3562.5 lbs
