#21 |
Liked 275 Times in 76 Posts
May be a really stupid question but check that the return is not connected to the vent on the cell, as its a one way check. This would dead head the pump and the regulator, the check may allow some flow but I would be surprised.
#22 |
Liked 79 Times in 11 Posts
return is unblocked. -8 line for a vent line.
bob beals 7244 |
#23 |
Liked 1,034 Times in 368 Posts
Is this a Fast system ?
Jeff Niceswanger 3740 SS |
#24 |
nope. stock with a Anderson pms, then I hooked up my rpm extender, then I tried just my stock ecu. all acted the same.
bob beals 7244 |
#25 |
You might try putting some foam in the cell... I don't have a lot of experience with injection, but sure sounds like it is running out of fuel or getting air in it.
With higher pressure of injection and a lot of return at high pressure, if it is putting air in the cell, getting air in the line, it will cause headaches... Keep working on it, you will find it. Ken Stock 412 |
#26 |
thanks. I will try that.
bob beals 7244 |
#27 |
Liked 11 Times in 8 Posts
Bob, does your return have a dip hose inside the tank so it's putting the fuel in below the fuel level? Personally if you were getting air in the system I would think you would be able to hear the pump surging and you would see pressure fluctuations. Have you ever looked in the tank with pump running to see if it looks like the fuel is being aerated? When you say it starts to go lean, does it go a full number or just a few points lean and if your bring it back below 4500 does the AFR come back to normal?
Joe Buchanan SS/BX 3117 |
#28 |
Liked 323 Times in 63 Posts
Is the fuel cell outlet facing to the rear of the car?
Bob Shaw V/SA 515 |
#29 |
yes fuel outlet to the rear. return is right above it on the top of the cell. no foam so I think we have a winner with the airiation from the return. gonna put a tube in there and see how that works.
bob beals 7244 |
#30 |
Liked 1,958 Times in 593 Posts
For testing purpose dump the return line into a separate container. That would fully eliminate any aeration from the return
Mike Pearson 2485 SS |
