Old 11-04-2015, 03:57 PM   #21
rod butcher
Liked 132 Times in 27 Posts
Default Re: New Approved 305 Stock/Superstock Block..
Originally Posted by Jody Lang View Post
FYI
Just know that the Dart block is approx 50+ lbs heavier than a stock block.
The bow-tie block is 25lbs heavier than a filled stock block.
rod butcher is offline   Reply With Quote
Old 11-04-2015, 06:12 PM   #22
Signman
Liked 269 Times in 99 Posts
The extra weight would be a negative if not willing to take advantage of more stable cylinder walls for better ring seal and overall stronger block that probably doesn't move much at all at this power level.
Old 11-04-2015, 06:45 PM   #23
Greg Barsamian
Liked 427 Times in 97 Posts
What's the Part number for the Small-bore Bow Tie Block?
Old 11-04-2015, 09:46 PM   #24
GregP
Correct me if i am wrong anybody, but best to my knowledge the bow tie small bore thats was actually accepted for Stock elem is no longer made.
GregP is offline   Reply With Quote
Old 11-05-2015, 09:38 AM   #25
rod butcher
Greg,
10051182 is the part #.
rod
Old 11-05-2015, 11:40 AM   #26
GregP
Question Re: New Approved 305 Stock/Superstock Block..
Originally Posted by rod butcher View Post
Greg,
rod
Hey Rod, is it still being manufactured? I thought it was discontinued...
Old 11-05-2015, 11:46 AM   #27
GregP
I was looking around and found a Bow Tie block#10051182 on eBay for $2,800 while the Dart Little M is $2,400. granted the little m is a little heavier I will stick with it.
Old 11-05-2015, 01:02 PM   #28
rod butcher
Greg,
The bow-tie block has been discontinued some years back. I bought one for a spare. from Allen Patterson and he brought it to Indy this year for me. If money is an issue I wouldn't hesitate to use a stock filled block. My back-up motor ( stock 627 block filled) is within 4 hp of my bow-tie block. Good luck with your build.
rod
Old 11-05-2015, 01:38 PM   #29
GregP
Greg,
rod
Hey Rod, I figured they were discontinued a while back as I mentioned above. it would be nice to save a little weight with one but as we said they are hard to find. thats why I went to NHRA in regards to approving the Dart and was lucky they did,lol
Old 11-06-2015, 09:44 PM   #30
Rick Leininger Jr.
Good job doing all the leg work for those that want or need a block like this, hope it all works out well for you.
For a from scratch 305 stocker combo, I would prefer to use a new 350 based sleeved block, which I know puts me in the minority.
Rick Leininger Jr. is offline   Reply With Quote
