Old 11-06-2015, 11:26 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1968-69 396 & 427 Block & Parts
1969 396 4 bolt standard bore block that has been cleaned and pressure tested with casting number 3955272 dated H-30-8 and stamped T0429JH 19W497473 $1500.
1968 396 4 bolt 30 over block has been cleaned and magged casting number 3916323 dated L-2-7 and decked $1500.
6223 steel crank cleaned and magnufluxed ready to go standard on mains and rods $350.
3/8 dimple rods $300
8 inch factory timing cover $150
8 inch harmonic balancer $100
Factory big block oil pan $100
BBC oil pan with bolt hole on bottom side and looks to hold 6 quarts $50
1969 427 4 bolt warranty counter exchange motor casting number 3963512 dated L-9-8 and stamped CE956450. Motor is complete from intake to pan with correct 3919840 square port heads dated A-21-9 & A-16-9. The intake is a aftermarket edelbrock victor 2 aluminum square port. The engine is standard bore with the 7/16 dimple rods and the factory pistons still in place with the numbers 343-99 pm the underside. $4500 for the complete engine and is very clean on the inside.
1969 396-350HP CE engine complete from the intake to the pan casting number 3955272 dated J-4-8 and stamped CE969319. The motor has the 6223 steel crank, intake 3931063 dated B-19-9 and heads 3931063 dated B24-9 & B-26-9. Motor was rebuilt and never fired and is standard bore $3500.
1969 1111497 distributor dated 9-C-5 for 1969 March 5th $175 with the factory coil bracket.
1969 3919840 square port heads both dated A-21-9 and have been cleaned and magged ready to go $1750.
Can ship if you cannot pick up and can provide pictures with an email address. I can be reached at 330-770-2517 for any questions.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
