I am going to be restoring an old Super Stock car. The rear clip has been replaced along with a new cage installed. So I am planning on rebuilding the car as a legal Super Stock. What modifications can be done to the fame and what are normally done. All mods, bushings control arms, relocations, frame mods that are legal. Thanks Dan
Liked 1,944 Times in 585 Posts
You can cut the center of the frame out for oil pan clearance. Double adjustable shocks are needed on the gen 1 Camaros. Bump steer kit. Stock A Arms must remain. Good springs. New bushings and ball joints. After market disc brakes.
Mike Pearson 2485 SS |
I have been reading on here about not using poly. I saw someone makes spherical lower ball joints as well as the delalum bushings. I am a first gen Camaro guy. I did not buy this car 18 years ago but took the second chance. I am seeing some creative front end work that was done. Originally built and raced by Joe Scott. Which is the better engine combo, 327 or 350 to run? I have Moroso front springs. Was leaning toward Calvert, but want to hear what the guys who race know what works. Car has stock front floors and new S&W ladder bar frame. The trunk floor center is in. The rest of floor is gone. Can I use plain steel to replace what is missing. from the frame rails out to the trunk drop offs floor under rear seat area, and flooring over the rear end or does it have to be factory metal? So if you remember this car you are at least 55 years old.
#4 | |
