Old 11-10-2015, 11:53 AM   #11
Dragsinger
Liked 99 Times in 60 Posts
Default Re: tranny cooler
"be prepared if you have to make multiple passes which will produce enough heat to hurt the trans"
that is my thinking and I always plan to be in the late rounds
Larry Woodfin 471W
Old 11-10-2015, 12:43 PM   #12
GregP
Recently I talked with they guys at Turbo Action and Scott Mclay in regards to this. they both told me it wasn't needed. but if you plan on making back to back passes etc then it would be a good idea.
GregP is offline   Reply With Quote
Old 11-10-2015, 12:47 PM   #13
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Originally Posted by njk53 View Post
If you have an in-tank transmission oil cooler (TOC) in your radiator, I would use it because it will help put heat into the transmission faster than without one.
As far as needing a TOC Auxiliary Cooler, I personally think one isn't needed because the transmission will not make enough heat in one pass to require a cooler. But, you also want to be prepared if you have to make multiple passes which will produce enough heat to hurt the trans.
We have used our in-tank radiator TOC for years with no problem.
I've been wondering for a while if the car might ET more consistently with the stock-type in-tank cooler. Seems like the trans fluid temp would be more consistent, though maybe higher than with an auxiliary cooler.
Dave Muller is offline   Reply With Quote
Old 11-10-2015, 12:59 PM   #14
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: tranny cooler
Ever since I first started learning about cars, I heard that heat was the main cause of automatic transmission failures, usually due to fluid breakdown (at least on the street). With that in mind, I always ran a cooler and now Amsoil synthetic transmission fluid. Granted that modern technology has deveoped more durable parts & fluids and the firm shifts from race valve bodies reduce slippage and heat. But you'll still get a build-up when they start "hot-lapping" and especially with trans-brake equipped cars. So I figure it's good insurance and worth the little extra weight and time needed to disconnect hoses for R&R.
So Mike Pearson knows more people with coolers than he thought!
LOCOMOTION Racing
Old 11-10-2015, 02:53 PM   #15
njk53
It isn't the heat that is the enemy of your transmission, it is excessive heat that destroys the internals of a transmission. I have always liked the radiator in-tank (water to oil) coolers, because of the fact the transmission will get up to operating temperature quicker, and in turn lubricate the internal components better and faster. Also, an in-tank cooler (water to oil) cooler is more efficient than an Auxilary (air to oil) cooler.
Nelson Kowal
Stock 345
Old 11-10-2015, 03:06 PM   #16
SSGT Mustang
Liked 204 Times in 54 Posts
I just removed my cooler and fan, and put a dual Moroso heat sink in place of them. You can mount it on the frame rail to get a little weight off the front, and it's supposed to cool pretty well.
We'll see.
SSGT Mustang is offline   Reply With Quote
Old 11-10-2015, 05:04 PM   #17
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: tranny cooler
I run a trans cooler just to be safe. The cooler lines and cooler can't possibly slow you down they only weigh a couple of pounds.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-10-2015, 06:36 PM   #18
Dan Timberlake
I'd be inclined to plumb a trans temp gage into an external bypass line to see whether I needed a cooler, or not, without sacrificing a transmission un-necessarily to find out.
External coolers in the radiator started as a Heavy Duty option on some cars of the 50s/60s. Standard was air cooled via holey Bell housings and finny torque converters.
https://s-media-cache-ak0.pinimg.com...389a122d8a.jpg
http://forums.aaca.org/uploads/month...3142564952.jpg
Dan Timberlake is offline   Reply With Quote
Old 11-10-2015, 07:05 PM   #19
MontyF
Monitor your tranny heat. Late rounds my glide only runs little over 180 degrees with no cooler. It's a ten second car and I don't stall it out on the two step.
There is nothing wrong with running a cooler but not needed if heat isn't a problem.
MontyF is offline   Reply With Quote
Old 11-10-2015, 07:38 PM   #20
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
I want to thank everybody for your input. I am happy I am to the point where I need to start making some "real" race part decisions for the build. Want to have tranny ready in car when i drop motor in. It's been a long haul (2 plus years) but a painted done roller now.
Will Lamprecht Div 1 I/SA 65 Impala progressing !
