Is there a good, easy to use product for getting rid of trailer chalk on a white trailer?
Liked 807 Times in 247 Posts
It might be a little extreme but I bought a used trailer a few years ago that was majorly oxidized plus brown ooze running down from the screw holes in the skins (rust coming from the ms inner frame tubing). I tried a little bit of everything but what worked best was wiping down the whole exterior with lacquer thinner, then scrubbed it down with car wash soap followed by car wax. It worked great and was a fairly quick process. I wouldn't recommend doing this on a regular basis as I assume this was pretty rough on the enamel finish but as a one time thing, it worked well.
Liked 286 Times in 88 Posts
Castrol SuperClean works good also, 1 panel at a time. Wipe it on the rust and takes it off almost instantly. Hope this helps…MB.
On our aluminum sided RV we use Meguiars #49 and then # 50. We used to buy it in the gal size. Here is a link to their website with more info.
http://www.meguiars.com/content/glob...eRVCatalog.pdf
old 1608 stock racer |
Liked 336 Times in 183 Posts
simple green straight--- wash from the top down one section at a time----- then rinse thoroughly---worked for me--
