Old 11-10-2015, 10:38 PM   #21
CMcAllister
Liked 920 Times in 259 Posts
Default Re: tranny cooler
I had one of the old Russell heat sink coolers mounted under the car near the trans to keep the lines short. It is able to be disassembled and cleaned if needed. Nice, clean setup that didn't rely on airflow. Trans temp gauge with the sender in the pan. I was satisfied with how it worked. 6k converter in a Glide in a .90 car leaving on the mat.
Old 11-11-2015, 10:58 AM   #22
Ed Wright
Ed Wright's Avatar
If you buy one of the better professionally built transmissions you often find plugs in the cooler fittings, and the cooler bypassed internally, therefore don't expect a cooler to help.
Ed Wright 4156 SS/JA
Old 11-12-2015, 09:45 AM   #23
buzzinhalfdozen
Liked 11 Times in 8 Posts
If you buy one of the better professionally built transmissions you often fine plugs in the cooler fittings, and the cooler bypassed internally, therefore don't expect a cooler to help.
You're right on that one Ed, had to work on the pump on the T-350 to make the cooler circuit work. The Pro-flite was easier, but should probably call the manufactuer to verify if there is any doubt.
Joe Buchanan SS/BX 3117
Old 11-15-2015, 11:18 AM   #24
ken robinson
Liked 224 Times in 87 Posts
Ask your trans guy if you need a cooler and ask him where to install a temp gage sensor. Can't wait to see you at lebanon . Ken R
Old 11-16-2015, 06:57 PM   #25
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Many racers use their cars for dual purpose. Bracket racing / Stk/Ss. I would not want to hot lap any transmission to sacrifice a few lbs.
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 11-17-2015, 08:13 PM   #26
joe huestis
Liked 409 Times in 113 Posts
Thumbs up Re: tranny cooler
Will,
Ran the Monza for a short time with no cooler. All was fine until I would have to hot lap it in the late rounds at some of our CCRA races. Consistency fell off noticeably. Put a cooler back on , consistency came back, ran the number, won some cash. My vote put a cooler on it and no worry... - JOE
Joe Huestis
Youngsville, NC
Old 11-17-2015, 09:57 PM   #27
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
A cooler is OK to run, but doesn't do much without some airflow running through it. The OEM's usually run an in-tank radiator cooler, and on the Heavy Duty packages add a second cooler, usually an air to oil cooler in front of the radiator. One system I saw a racer made a air to oil cooler system with a set of valves to bypass the cooler. He had a transmission temp gauge and basically bypassed the cooler until the trans got up to the temp he wanted to run at. Best of both worlds !
ss3011 is online now   Reply With Quote
