Old 11-19-2015, 10:17 PM   #11
George Mirza
Default Re: Low power stockers-auto or stick
Originally Posted by House of Darts View Post
I chose an F body with the 318 4BBL. Surprisingly no rust. I have the motor in and before I chose a trans and rear combo, I just wanted to do it once and devote the time to tuning and racing. Paul, your help was put to good use. Thanks
This combo uses probably the best automatic transmission ever used in a stocker, take advantage of it.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
Old 11-20-2015, 04:24 AM   #12
GTX JOHN
Liked 2,516 Times in 701 Posts
Put in a decent 904 and B body 8 3/4 (5:13) and you will seldom have a problem.
A good second under combo without anything exotic ( check out Pomona
Qual. sheet).
John Irving
741 Stock
741 Super Stock
Old 11-21-2015, 10:10 AM   #13
Liked 10,965 Times in 2,260 Posts
stick=dana
Old 11-21-2015, 10:30 AM   #14
GTOMayhem
Liked 22 Times in 14 Posts
What about a 3rd or 4th Gen F body with an Iron Duke or a V-6? Would you have the same issues with a stick?
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 11-21-2015, 02:45 PM   #15
Robert Swartz
Robert Swartz's Avatar
A wise man once said, Buy the good parts the first time ......
Pretty simple premise we had in the old days. When you could find stuff lying around "cheap". By time you had fixed your car 3-4 times breaking your "cheap" parts. You figure out you'd have been dollars ahead to have bought good parts in the first place.
Most of my old cars may have looked like POS but I tried to get the best parts I could find. My Mustang II will follow the same pattern.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 11-22-2015, 10:41 AM   #16
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Im looking at building a U/S 302 2V combination but instead of going dime rocket I am going fairly cheap engine along with a very good Strange rear end with Jerico or G-Force Tranny with a Mcleod Soft Loc. It will not be a dime rocket or cheap but instead maybe a 50 cent rocket that will live and I am figuring it should cost around 20 grand or so for the complete build.
Rose Racing is offline   Reply With Quote
Old 11-22-2015, 12:28 PM   #17
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
I agree with the comments about no matter what HP a Jerico tranny with the right clutch is the only way to go. My experience withy my 68 Impala i ran with BBC (396/325) I had 100 passes on that Jerico and in my buddies SBC 68 Camaro 11.30 car has another 250-300 , tranny still good, never a problem. Also the rear needs not only Spool but Pro-Gears, my only breakage was from using "Street" (cheap) gear set.
I think the Jerico is one of the best aftermarket part made.Just my opinion.
Will Lamprecht I/SA 65 Impala in progress.
Old 11-22-2015, 03:39 PM   #18
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
A good trans and clutch, is a wise investment. Used Jerico's and occasionally a G-Force come up for sale and that will get you in the game. A clutch is very versatile from a tuning standpoint. If the clutch is built with low base to begin with, it allows for a wider HP tuning range. A low HP engine will not be happy if the clutch is tugging the engine down too low because of too much base. Keep that in mind when looking at clutches, and a stick car can be very consistent as well.
Sean Marconette
84 Mustang
5060 SS/N
