Old 11-28-2015, 08:46 PM   #1
Buick6
Liked 16 Times in 7 Posts
Default Replacing Steering Column On A Regal
I need to get rid of the column shift steering column in my car. Can a stock eliminator car have a racing type steering column or will I need to find an OEM floor shift type steering column?
Buick6 is offline   Reply With Quote
Old 11-29-2015, 08:49 AM   #2
Billy Nees
Default Re: Replacing Steering Column On A Regal
You need to find an OEM floor shift column. Any G-Body will fit.
Billy Nees 1188 STK, SS
Old 11-29-2015, 10:20 AM   #3
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Billy, couldn't you just "disable" the column shift ? On my 65 Impala I kept the column shift steering column removed the shifter arm, cut the shifter arm housing off, patched up the hole. I even removed the shifting mechanisms. The only thing left still on column is the gear selection window. I can't see NHRA not allowing that?
Hope you find that motor mount for my buddy Pat 6 cylinder, want to go racing next year in H/MP
oops, I forgot NHRA got rid of the real Modified Eliminator years ago. Coolest fast Sportsman eliminator ever.
Billy by the way I have the brake system all finished, thanks for your help.
Will Lamprecht I/SA in progress, 2016 debut at a local Div 1 track near you.
Old 11-29-2015, 10:33 AM   #4
Buick6
Thank you.
Old 11-30-2015, 12:24 AM   #5
henrys57wagon
henrys57wagon's Avatar
Here is an 84 Monty tilt column in my 57 with both the key and shifter removed filled and painted.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
