Old 12-08-2015, 01:01 PM   #61
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Bypass fuel pressure regulator systems
you haven't moved on neither has the OP as evident by your replies to my posts and as long as that continues, I'll continue to reply and I'll continue to ask...
for somebody that claims via pm to the OP, that they have improved their car's performance on the track by just adding this bypass to their regulator, to please enlighten me how a pair of -3 hoses plumbed into a regulator makes additional HP, enough HP to run quicker and faster as evident on the time slip because without it, there is NO quicker 60 foots and ET regardless of what John tells him or you, those without the conviction to post publicly and engage in reasonable dialog stating your OPINION based on your belief and JUSTIFICATION for choosing to spend your $ on a regulator bypass.
As far as my cars performance, the fact remains that my cars are quicker than yours and 99% that posts here so not so common around here!
Old 12-08-2015, 05:39 PM   #62
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Will you two just quit?!?!! It has become nauseating.
Old 12-09-2015, 05:28 AM   #63
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
In the OP's original question, he was looking for "results" from 4 areas, not just ET/MPH. He also wanted to know if any had experienced steadier pressure or any annoying side effects.
I'm learning from Most of the people posting to this.
Dave Noll, EF/S ,?/SA 6526
Old 12-09-2015, 06:45 AM   #64
1320racer
1320racer's Avatar
Originally Posted by nhramnl View Post
Has anyone converted their carbureted combination to a bypass system? I'm talking about a system that uses small lines from the pressure regulator that go into a y-block and then back to the fuel cell. If so, it would be great to know what your results were (steadier pressure, additional MPH, ET improvement, or annoying side effects). Thanks.
So again...NO to steadier pressure, NO to additional MPH, NO to ET Improvement and the only annoying side effect will be his lighter wallet and the foolish feeling that will come over him for believing that the addition of two -3 hoses plumbed into his regulator would magically have his engine making additional HP, enought to show even a few hundredths in ET and MPH on his time slip.
