Old 12-20-2015, 09:25 AM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default 2007 Chevrolet 5500: steering and brakes
A little off track here, but my car hauler (toter home) has a major problem (problems ?) that currently make it unusable.
It started with the brake alarm going off and staying on. Topped off the hydraulic fluid, but made no difference. Next, the steering locked up. Drove home from Bowling Green at 40 mph not knowing when it would lock up.
Are these two systems related? I don't want to take the truck to the Chev. dealer if possible. What can I do myself?
The truck only has 12,000, easy, miles on it.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 12-20-2015, 11:56 AM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: 2007 Chevrolet 5500: steering and brakes
Not sure why the steering locked up but when we had our Kodiak 5500 motorhome our brake alarm and dash warning leaving a race track stayed on. After several tries to get it out we found that the brake lite switch was bad. After googling this issue the brake lite switches are a common problem especially of you have a brake controller hooked up. Replace the switch drove it 100 yards and the problem was fixed.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 12-20-2015, 05:31 PM   #3
rod butcher
Liked 132 Times in 27 Posts
On my GM 5500 I had a rear abs sensor go bad due to a caliper issue and also had a small relay under the master cylinder that controls the electric side of the brakes burn up from getting moisture in it. As far as the steering, I have't had a problem. Borrow a scanner tool and see what codes you have for the brake system.
rod butcher is offline   Reply With Quote
Old 12-20-2015, 06:45 PM   #4
Bobby Zlatkin
So, I take it from these two responses that I have separate problems. The two systems are not integrated.
I'll try the brake light switch first (as soon as I figure out where it is) as it seems the easiest and yes, I do have a brake controller hooked up.
Old 12-20-2015, 07:45 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Ouch ! May have burnt up the trailers brakes .
ss3011 is online now   Reply With Quote
Old 12-20-2015, 08:37 PM   #6
jmantle
Liked 172 Times in 81 Posts
I'm not sure about the gas pots but if it's a diesel, the systems are related in the fact the power steering pump also supplies the hydraulic pressure for the brake booster.
As Bob said, the brake light switches are a big problem. I did figure out that pulling the radio fuse shuts up the alarm until you can get it fixed.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 12-21-2015, 08:48 AM   #7
Mile High
These trucks have a hydro-boost system. It works the power steering and power brakes. Sounds like the pump is acting up. Maybe this will help.
http://www.brakeandfrontend.com/oper...ssist-systems/
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
